Electric Mobility Rascal Scooter Wheelchair Batteries Logo
J
Jane Posted on Nov 17, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Scooter runs fine but when I come to a stop, it shuts off and I have to turn the key and and off before it will start again. It has new batteries and is fully charged.
Scooter Doctor
Level 3:
Master:
  • Electric Mob... Master 401 Answers
  • Posted on Apr 12, 2016
Scooter Doctor
Level 3:
Master:
Answers
401
Questions
0
Helped
122556
Points
1542
You are loosing connection in your control circuit, check all connections including the batteries and their connections.you can also see other options at Scooter Doctor App
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
5 Related Answers
Anonymous
  • 92 Answers
  • Posted on Apr 06, 2010
SOURCE: I have purchased new batteries for my mobility
The control seems to be the issue. I have rewired so many scooters. When you have power and it wont go, it is usually the control. If you cannot afford the part right away, you can rewire it or have it rewired direct
Anonymous
  • 177 Answers
  • Posted on Jun 07, 2010
SOURCE: Scooter stops intermittenly
Hi. Does the machine stop suddenly, or does it slowly stop as it normally would? Does this happen on hills or slopes?
A lot of scooters have a self-resetting circuit breaker connected to the battery leads. If the machine draws to much current ( amps ) then the circuit breaker trips out. After a few minutes the circuit breaker will reset and you can continue.
This could mean that the circuit breaker is faulty or that the motor is drawing to much current, or is burnt out.
Some machines have a very light duty circuit breaker, and these can trip out often. I have changed many of these circuit breakers for this reason.
Check all your battery leads are secure and tight.
If it is still a problem, get a serviceman to check the motor current is what it should be.
Good luck. Neil.
Anonymous
  • 177 Answers
  • Posted on Jun 17, 2010
SOURCE: With new charged batteries, scooter shuts down
Hi. I have had this fault on a few machines, but its not always the same problem.
When scooter motors have done a lot of work, they develope a build up of carbon dust from the brushes. This dust can cause a short or the commutator might be slightly out of round, causing the brushes to vibrate or bounce. The electronic controller is always monitoring the speed of the armature, and if this signal is interupted, the the controller can shut down the motor. Test the motor with a multi-meter on OHM's, from one of the brushes to the frame of the motor. If there is no circuit, then there is no build up of carbon. If there is a circuit, then you might need to overhaul the motor.
Also check the battery lead connectors, and the motor lead connectors. I have had to remove many of these for bad connections. Really bad connections will have burnt or melted the plastic housings.
Good luck. Neil.
Anonymous
  • 3085 Answers
  • Posted on Jun 27, 2010
SOURCE: Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
Rich Miller
  • 46 Answers
  • Posted on Jul 11, 2010
SOURCE: scooter runs then stops I turn offf the key and
the batteries are worn and problably need replaced , the computer will stop running the scooter at threshold voltage, older batteries and will hit this threshold voltage and slow the scooter
1helpful
I HAVE A NEW WUXING TRICYCLE MOBILIY SCOOTER(NEW) REPLACED BATTERIES AND FULLY CHARGED. BUT SCOOTER WILL NOT RUN
Sounds like you have a bad relay in the motor controller. I would see if you can get it warrantied if it is new
1helpful
I have a Pride 4 wheel Go Go Elite Traveller Scooter. It generally works fine, but I will frequently get an 8 beep error code and it won't go after a stop. I merely turn the key off and then
BEEP CODE CONDITION SOLUTION
2 Battery voltage is too low to operate Charge the batteries fully until charger and
the scooter. any meters indicate completion.
3 Battery voltage is too high to operate Contact your authorized Pride Provider for
the scooter. assistance.
5 Solenoid brake trip. The manual freewheel Remove the key, then push the manual
lever may be in the freewheel position. freewheel lever to the drive position and
restart the scooter.
6 Throttle trip. The throttle control lever Release the throttle control lever completely,
may have been depressed while inserting then reinsert the key.
the key.
7 Throttle trip. Throttle potentiometer Contact your authorized Pride Provider for
fault or speed potentiometer fault. assistance.
8 The motor is disconnected. Contact your authorized Pride Provider for
assistance.
9 Possible controller trip. You may be Shut down your scooter for a minimum of
attempting to install the battery pack while several minutes to allow the controller to
the key is inserted or the motor controller cool. Or, try reinserting the key into the key
may be in overheat protective mode. switch.
What you may be doing is mis-counting the beeps and it may be 9 beeps or its 8 and you have a bad connection between the motor and the switch? Good luck!
This problem is on my Pride Mobility Scooter/Wheelchair. I am trying to figure how to keep from having to turn my key off and back on to free up my brakes after they stay sticking after I come to a co
I am not familiar with this but it sounds like a problem in the control module or one of the sensors. You may want to take it to the dealer to get checked out.
3answers
Scooter shudders when starting and after stopping
hi, now firstly you need to check all connections fitting all plug connectors, remove one battery lead before proceeding so you don#t accidentally short something ... Now having done that you need to make sure the break is not losing power otherwords coming on, Check the brushes and let me know how you get on ...
Regards
Rob
www.gewizrepairs.co.uk
Scooter keeps stopping randomly. The battery level near to the speed lever drops quickly to red, scooter stops. Turn it off then on again and fine for a bit - then same happens?
These units are 24 volt systems. If the voltage at the controller drops below 18 volts the controller will cut out. Shutting the unit off and back on resets the controller. Since your battery gauge is dropping into the red when accelerating your batteries are suspected to be bad. If the batteries LOAD test fine then check your battery harness and circuit breaker wiring for a loose and / o r hot connection after riding it.
1helpful
I have a Pride legend three wheeler- I replace the battery charger because it would not charge the batteries. I pluged the new charger into the control module it will charge the batteries. Batteries are...
if I understanding this correctly , you cannot use the scooter why it is being charged, there is a inhibit pin that stops the scooter from being used,
All scooters are designed this way.
Regards
Hi my scooter will go then stop but when i mess with the controller it seems to be all right for a little while i cant afford a new one any help will be apperciated than you Donna
My scooter has just stoped working the battery was low but not too low when I shut it off it would not start again. I charged the batteries and the meter shows full charge but it will not run.
I pushed the reset button, still nothing.
1helpful
Scooter runs then stops I turn offf the key and then it runs again and then will stop again also the scooter seems to have lost speed over time
2helpful
2answers
Strider chair starts and stops
Troubleshooting for this model is now available at
http://www.striderscooterservice.com/blink-codes.html
Top Electric Mobility Health & Beauty Experts
Rob Hill
Rob Hill
ZJ Limited
ZJ Limited
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
