I need the software that can run on windows 7 or windows 8 both 32 and 64 bit
Hi..please search futura -support.com.All details are mention here for install window 7 64 bit or 32bit compatibility s/w and install procedures.
I have a futura basic software & 2.5 upgrade software if anyone want please requst [email protected]
That is called the upgrade or compatibility software, and I would recommend that you search on eBay under Singer CE-200.
SOURCE: Software not opening with Singer Futura on Windows XP
Bit out of my league can I suggest you talk to a computer expert.
My limited knowledge tells me while trying to update, your previous software package has been corrupted.
SOURCE: Futura CE-200 Software fails to initialize on XP sp2
Maybe you should try to contact singer south africa and ask them whats wrong, my laptop did the excact same thing switch over to home pc and no problem ever again.
SOURCE: My software won't run on the vista windows
I had the same problem. I called a singer service center and he told me that was a major issue with the futura....no software made for Vista. I was determined to find a solution and finally found a patch. Here you go: http://www.futura-support.com/downloads/patch.htm#
SOURCE: For Singer Futura CE 250. New laptop with windows 7?
Update with WIndow 7 support is already available at:
http://www.futura-support.com/downloads/ce150.html
If you applied wrong patches you will have to uninstall Futura, reboot, install from the beginning the basic version and then apply an update 3.0.0.9
SOURCE: Singer CE-200 Quantum Futura
i need the 2.5 upgrade software for my futura ce200 because i have windows 7 can i download it off the net??
