Contributor
- Posted on May 29, 2016
Re: Why doesn't the router recognize the Safaricom modem?
Reset the router to factory default. The default user and password is admin/admin.
Or if you have backup configuration, there is a software to read this file and extract the password for you.
Good luck
Hi Majlis Al Marif Al Islamiyyah, we want to help you with your question, but we need more information from you. Can you please add details in the comment box? Can you tell us what ip addresses are being used ? What is the TP - Link ip address and subnet for internal ip address and also what is the DHCP server IP lease range.
On the Safaricom Modem / Router what is the IP address and subnet mask set to and does it have a dhcp server activated that should be de-activated or at the very least not be running on two routers on the same network ? Note also two devices should not have the same ip address !
