Crafts & Hobbies Logo
Carina Villagomez Posted on Nov 16, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I got a pencil stuck in my hot glue gun. I was trying to push out the rest of the glue out and the pencil broke and now it's stuck. How do I take it Out plz help!!!
onlyadriana 24
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 21, 2019
onlyadriana 24
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5853
Points
Heat the glue gun and twist the pencil then., pull it out.
  • Ashley Bautista Orellana
    that is what i did than you that help's alot you dont not how that means to me
Ron Durham
Level 3:
Master:
  • Master 508 Answers
  • Posted on Nov 16, 2015
Ron Durham
Master
Level 3:
Master:
Answers
508
Questions
Helped
150384
Points
1661
Heat the glue up an remove tube glue from injecter then take a paper clip an push pencil out
Dez Storm
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 28, 2019
Dez Storm
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5946
Points
8
Don't let it get to hot or it could burn and completely ruin your glue gun but heat it up and use a small pointed object to push it out that wont burn easily.
    ket het hot to you can get it out you mean??
Sienna Schmitt
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Jan 23, 2019
Sienna Schmitt
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5853
Points
12
You can buy a new one.
buzzstine
Level 1:
Habit-Forming:
New Friend:
  • Contributor 13 Answers
buzzstine
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
13
Questions
Helped
17113
Points
34
If you can take a drill with a 1/8” or smaller bit and get a hole drilled a half inch or so into the core of the pencil, then you can get a screw turned into it and use pliers to pull on the screw, which should also pull the pencil out.
tip
Jammed Glue Gun
I replied to a post of a jammed hot glue gun pencil stuck it closed my cure was to reheat it an use a simple paper clip to push it out an clear:-)
on Nov 16, 2015 • Miscellaneous
How I was trying to push hard glue out of my glue gun with a new pencil but then the eraser got stuck and I didn't realize so then I pushed it in again and the metal part came out and now I don't know what...
Sometimes the rubber nozzle removes easily and once removed the metal nozzle behind the rubber can be unscrewed with a wrench or pliers.
With the nozzle removed and the glue gun is hot it should be possible to push the eraser and the metal ferrule back through the heated tube of the glue gun.
If the nozzle can't be removed it poses some difficulty as a rod or stiff wire will be needed that will go through the hole in the nozzle to push back the eraser. It will probably be a fiddly job and it might not be possible to push the eraser right out but if it can be moved back a little it could be possible to hook it out with the same wire after bending it so there is a small hook on the end.
You made an honest mistake and your parents shouldn't be angry.
If you find you can't remove the eraser; if you have a car repair shop nearby, I am sure you will find help there. Once hot a quick blast of compressed air through the nozzle should clear everything from the heated tube.
Hi, I got a pencil completely jammed my glue gun and I turned it on and slowly pulled it out a little bit but is still stuck do u have any tips!!
First try and get as much glue that is left in between the left over pencil and the tip out. Then find something that is the same diameter as the tip of the glue gun and about 6 inches longer that the length of the gun. With the glue gun OFF jam the object into the tip of the glue gun until it comes out the rear of the gun. Whatever you find to do this needs to be stiff like wire or something of the sort.
I have a glue gun were I stuck a pencile in the hole in the back and now I cant get it out ????what to do ???
Turn on the gun so the glue heats up and then try to pull it out.If thatb doesn't worlk, you need to get a new glue gun.
How does a glue gun work?
A hot glue gun is a very useful tool for joining modelling materials and even more substantial materials can be fixed together with it. 'Sticks' of solid glue are pushed into the back of the gun, the trigger is pressed pushing the glue stick forward and molten glue comes out of the nozzle. The glue is manufactured from thermoplastics.
You can check out this site for more info:
Dear Experts, I need assistance from you ppl.I stay in India. I bought a medium quality glue gun and a glue stick. I plugged the gun to the power socket(220v)and waited for the glue to come out of the...
It takes a couple of minutes for the gun to heat up. When you first plug it in, touch the metal nozzle with your hand. It should become obviously hot within 15 seconds and too hot to touch within a minute . After it fully heats up (a couple of minutes), squeezing the trigger should advance the glue stick and push molten glue out of the nozzle. However, there is often an initial resistance to the trigger and you may have to squeeze a bit hard to get it started. If there is a problem with the trigger mechanism, you can also advance the glue by pushing directly on the back end of the glue stick with your thumb. Good luck.
Aug 04, 2010 • Garden
2answers
Glue stick is stuck in glue gun and can't be removed.
Make sure you plug in the gun so glue is soft if gun not getting hot the you have another problem
Glue Gun Question
Gather the materials needed and place them on a flat surface near an electrical outlet. Examine the glue gun. Locate the metal rest. This is usually attached to the barrel of the gun and is shaped like a "W." Make sure it folds out and locks into place. Locate the trigger. This is just behind the barrel on the underneath side of the gun. It should be a solid piece of plastic shaped like a slice of pie. Just above the trigger, is the barrel loader. This is where the glue sticks go into the gun. Inside the barrel loader there is a smaller round piece of plastic. This is what actually pushes the glue stick through the barrel. Pull the trigger and watch the piece of plastic move with it. Pick up the electrical cord and examine it. Make sure the prongs are secure and not bent. Make sure the cord has no breaks in the outer lining and there are no frays at the base of the gun where the cord attaches. Plug the glue gun into the electrical outlet. Allow the gun to heat at least 15 minutes so it reaches operating temperature. When the gun has heated at least 15 minutes, insert a glue stick as far as it will go without forcing it. Now pull the trigger until a small drop of hot glue forms on the tip of the gun. Practice gluing on the paper plate. Pull the trigger until a ball of glue forms on the plate. Release the trigger and quickly press the tip of the gun down onto the surface of the plate and pull it to the side. This will break the glue and stop it from stringing out when you pull it away. Continue practicing until you get the right amount of glue you want for the object you imagine using. When you pull the gun away, there may be a small string but this will break off easily. When you have the perfect amount of glue and only a tiny string forming when you pull away, you are ready for your project.
Top Crafts & Hobbies Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Carolyn Rogers
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
