Amazon Kindle 1 Logo
B
Barbara U Payson Posted on Nov 15, 2015
Message came on to push a button for longer reading. I pushed it and now it isn't charging. What should I do to finish reading my book?
3helpful
3answers
How do I delete a book from my device that I have finished reading?
To remove a book or magazine from your Kindle Fire HD libraries, follow these steps:
  1. On the Home screen, tap Books or Newsstand to display your library.
  2. Locate and press your finger on the item you want to remove. A menu appears.
  3. Tap Remove from Device press the helpful button
How to delete books from Kindle Fire HD
How to Delete from Kindle Fire
How to Delete Books and Docs From Kindle Fire HD8 HD10
The tablet keeps turning itself off
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before.
Kocaso m1068 will not power on
Support Troubleshooting Guide
Kocaso m750
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. Support Troubleshooting Guide
Tablet will not turn on
Model 766 will not take a charge
Battery charing very slow, can't open tablet - won't turn on when button is pushed
The battery on the Asus does take a very long time to charge (over 12 hours before you use it the first time, then 8 hours or more each time). It takes even longer if you charge it from the USB port in a computer rather than connect it to its dedicated charger, or if you use it while it's charging. If you've already charged it for 8-12 hours, try turning it on by pressing the power button *and holding it down* for a couple of seconds before releasing it. Then, when using the tablet, try keeping it hooked up to the charger when possible, or at least recharge it overnight.
You can check on battery charge by tapping "Settings" at the bottom of the Home screen, then tap "Battery" in the Device category. The % charge will be at the top of the screen. I enjoy my Asus tablet, and it's good for several hours at a time between charges, but you do have to keep it charged up. Good luck!
My wife just finished reading a book. how do i go back to the beginning so i can read it?
Open the book, press "Menu" button, select "Go to..." from list using the 4-way button, confirm by pressing the center of the 4-way, select "beginning" from the dialog that opens and press center again.
2answers
How do i mark the books to show that they have been read
Unfortunatelly Kindle does not have this feature. But the books you read get pushed down the list.
Or you can delete the book by using these steps:
1. Select a book and click the left arrow on the 5-way button that brings up a delete button the screen.
2. Press the center button and you delete the book.
Another option is to move the book to a collection this is like to archive the books you already read.
GoodLuck!
eBookBoy
http://digialreader.freeforums.org
Top Amazon Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Jennifer Rock
Jennifer Rock
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
