Has not been used in several years. Ran four different stitches to test and then it quit stitching.
1. It is likely the motor belt has broken. It is easy to replace. There are many youtubes on how to do this.
2. If the fabric is moving and the bobbin thread is inserted you will have two possibilities.
a. The tension of the bobbin needs to be set, replace thread with fresh thread (good embroidery thread-not Walmart). The thread can be checked by looking at it into a light. If you see fuzz get rid of it.
b. If you have replaced the thread and adjusted the tension and it still isn't sewing it will need to have the timing adjusted by a professional.
ALWAYS REPLACE NEEDLES WITH NEW ONES TO BEGIN WITH.
