They are sold with the firmware and language for the country they are selling to. You have to change the firmware to your country. Easy to do with a computer.
To change the language of your device, you must upgrade the firmware with the ... How do I manually turn off/on voice guidance on my Jabra Extreme2?How do ...
How do I reset my Jabra Extreme2?How do I pair my Jabra Extreme2 with my mobile device?How do I update the firmware or change the language on my Jabra ...
Your battery is no good. If you've had it for a while then the battery's life has been used up. All rechargable batteries have a certain amount of times they can be discharged and recharged. Once that amount is met end of battery. If it is new then send it back for a replacement.
All things can go defect. But to find out if it is your charger, cable connector or the battery you have to look very close. Perhaps you even try another charger and or try to charge an other headset.
When you are using this one for a couple of years now, day by day, perhaps it is time to start saving for a new one?
Hi. To turn Voice
Guidance off, press the Option button. To find the settings, press up or
down slowly until you hear a beep. Press OK to enter the voice guidance
menu. From that his menu: Voice Guidance On/Off: Use arrow keys on
remote to toggle on and off.
NOTE:This menu is spoken even when voice guidance is turned off.
Read more: Turn off voice guidance Jabra extreme 2? - Software to turn off voice guidance of jabra extreme 2 :: Ask Me Fast at
I just got mine and had the same problem. After messing with it for a bit I got it to work. The trick is you must have audio of some kind playing through the jabra when using the volume button. I started some music playing and then tried the button and it worked. But if it is idle you just get the battery status.
I just got mine and had the same problem. After messing with it for I bit I got it to work. The trick is you must have audio of some kind playing through the jabra when using the volume button. I started some music playing and then tried the button and it worked. But if it is idle you just get the battery status.
Okay, I had the same problem of Jabra Journey not talking anymore, 'voice on connected "etc. And instead it only made sounds like bing bing... Here's the answer and its so simple! Turn the unit off with the slider off/on switch, (symbols are - or o). Then, press and hold the button at the very end of the unit, (symbol looks something like sound waves), while sliding the power back on. That's all there is to it and you'll hear it start talking again.
