Porter Cable BSI550 W 5,500 Watt Generator With 10 Hp Engine No AC output
Sounds like the generator unit (sometimes called the generator head) has overheated and melted the insulation in the windings. This is the same as an electric motor "burning out", and if this is the case, then the generator is toast. If you happened to notice that the lights or fans were getting dim or slowing down before the breaker tripped (without the gas engine slowing down) then this is most likely the case and you generator is toast. But if the output just suddenly quit, then it is possible that some smaller electrical component has failed. In any case, it's not something external that you can easily reset or replace. Sorry for the bad news.
