To let you know that it's charging It will turn solid red or change to a different color when the charge is complete
I bet if you read the paper work that came with flashlight it will explain the operating functions.
Sounds like the batteries are not getting charged. Check to see if there was some packing material in place to keep the batteries disconnected for shipping.
please read and execute the commentaries. God bless you Charging Conventions
The majority of laptops will display a solid green, blue or
purple battery light to indicate that the battery is fully charged. Most
manufacturers indicate that a laptop is in the process of charging by
displaying a solid or blinking green, orange, blue or purple light. If
your battery indicator light is green, blue or purple, the battery is
probably functional, regardless of whether the light is blinking. If the
light is solid orange, the laptop is probably in the process of
charging.
Battery Error Coneventions
Many battery manufacturers use rapidly blinking lights to
indicate that a battery's charge level is low. In general, a laptop will
rapidly blink orange or red when its charge drops below a certain level
until the computer is plugged into a power outlet and charged. If your
laptop's battery indicator continues to blink rapidly in orange or red
or if it remains red even when it is plugged into the charger, it
indicates a problem with your battery or the charger.
I had this problem. If you have the original Nikon charger, insert the battery and press the calibration button. I dont know how, but it charged the battery fully.
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
if it show fully battery also when u charge your battery it show from the red indicate only tht is not a problem... u need to charge the battery fully ... untill the msg shown as charge complet .. so need not to worry about the Red blinking battery indicator when you plug in charger.
