Defy error code e6
The E6 error is telling you that the clutch is causing the error or fault. This fault can happen if a paperclip, nail, coin, or a different object is jammed in between the tub and pulsator.Nov. 30, 2017
Hello Tj,
\The E6 error is telling you that the clutch is causing the error or fault. This fault can happen if a paperclip, nail, coin, or a foreign object is jammed in between the tub and pulsator. To clear the E6 error code on a top load LG washer: Take out all clothing or towels from the washer.
https://youtu.be/qa6_ViM3xug
Hello Tj Sunday,
Good Luck,
JP https://youtu.be/qa6_ViM3xug
Oddly, the user manual does not list an error code e6. Rather, it stops at error code e5. Sinotec is a South African company and its home webpage mentions service centers there. I find no online reference to this particular error code for this brand. Although one might post a query about such to the following site, I am not sure you would get a reply: https://removeandreplace.com/2015/05/05/washing-machine-error-codes-front-and-top-load/
Rather, you might query the Sinotec contact: https://www.sinoprima.co.za/get-in-touch/
The following FAQ page would seem to put you in contact with a repair center which might offer an explanation: https://www.sinoprima.co.za/faq/
I simply do not find this code explained elsewhere.
The E6 error indicates that the clutch is malfunctioning. This usually occurs because a foreign object is lodged between the pulsator and the tub/drum. Take all items out, and check the seam between the tub/drum and the pulsator for objects such as zippers, coins etc.. Take them out with pliers
? 3:04
https://www.youtube.com/watch?v=sYNN1Rvc7r0
Dec 18, 2012 - Uploaded by MitsubishiHVAC
1-Time Flash & E6 error troubleshooting, part 2 of 3 for Mitsubishi Electric Cooling & Heating - Duration: 2 ...
LG ElectronicsAn OE error code indicates the washing machine is draining slowly or not at all. This is usually ... When you see the E6 error icon, it means there is a clutch error.
