Tape was stuck, pulled it out tape was twisted and tore in half but i can fix the tape but the carriage is stuck so it keeps turning the tv Off, I need it to be (Unstuck) so the tv won't keep turning off, How do you get the (Cariage) in the vcr Unstuck? and thank you very much Sirs
It sounds as if the drive belt or wheel that controls the carriage has perished and failed. There is normally a micro switch on the side or rear of the tray, that senses the presents of a casset. If it is closed with stikky tape or clay you may be able to simulate a casset in the machine and with manual force help the casset to open or close. alternatively a small lamp in the centre of the tray senses the tape. then you have to cover the lamp or two sensors on left and right side of the tray, to prevent detection of the broken or missing tape.
Hello tcsabug,
First locate the load and unload motor, it is the one with the rubber drive band. release the drive band and rotate the gear to raise and pull the carriage back into position.
This should remove your cassette, and put the carriage back into position.
I hope this helps,
Thank You,
Shuttle83
