Question about Mitsubishi WD Televison & Video
I have replaced the dpl chip and now the picture has black and white verticle lines. Is it the color ribbon now?
  • Rhonda MacFadzen
    Rhonda MacFadzen Nov 14, 2015
    now the picture is white with black dots and the lines are gone after I plugged into a different hdmi port.
    New Friend:
  • 40 Answers
It means that some of DLP connections are either misaligned, or have failed to make a connection. Reheat the connections to try correct this or re-align the DLP chip. This ususally is a nightmare! Regards.
Posted on Jan 05, 2016
6ya staff
SOURCE:
Ronnie Houston
  • 2920 Answers
SOURCE: The picture is in black and white but menu is color
you might have the colorwheel checked to see if its bad
Posted on Nov 03, 2008
Anonymous
  • 8 Answers
SOURCE: Black and white picture
you have the cables hooked up the wrong way
Posted on Nov 09, 2008
Anonymous
  • 1139 Answers
SOURCE: color of the picture is faded/green
Hello Jdillon917,
I understand what you are saying, however the devil is in the details in reference to your problem. Let me explain, DLP Televisions use what is called "Color Wheel Technology". A wheel made up of primary and secondary colors spin at a synchronized rate with the Luminance Video signal and this along with the changing of the mirrors of the DLP processor creates the color that you see on the screen (This is a high level description, but it covers what is happening). Now what you are experiencing can happen if the sync between the signal to the color wheel and the DLP processor is off center, if the color wheel is out of alignment, or if the signal to the DLP is drifting. The bulb "light" is working but something happened to interfere with the sync between the color wheel and the DLP processor. I would suggest getting this looked at by a DLP qualified TV technician, because of the nature of this problem. In addition I would request that you have the technician do a certified alignment after the problem is taken care of.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Jan 19, 2009
Anonymous
  • 139 Answers
SOURCE: verticle black lines on mitsubishi dlp tv screen
Press the Menu Key on your remote. If your menu shows clearly on the screen, then there is a problem with your source.
Posted on Mar 06, 2009
Anonymous
  • 33 Answers
SOURCE: black and white picture only
The color wheel is not the problem. If the spinning color wheel is impaired in its RPMs it will cause picture distortion, not black and white picture. If the color wheel looses any of its color fins, like if it is broken, there will be a loud vibrating noise inside the tv which you did not mention. Also if the color wheel is broken and doesn't spin, the tv will not start up.
The likely problem is on the digital control board or the power supply and should be referred to a local repair shop for repair.
There is an outside chance that you will receive color if you experiment with using all of the different input ports to see if you can find one that will bring back color.
Posted on Apr 29, 2009
Hi! Does anybody know how I can fix this tv screen? Is the screen smashed? Or is it just a chip replacement or something like that? // regards allan
If you see colors it means the screen is damaged internally and you need to buy a new one. If there isnt then it might be the front protector that needs replaced. If you see horizontal or verticle black lines then it is a chip issue
Oct 11, 2018 | Televison & Video
We just replaced the DLP chip in our mitsubishi 1080P tv because we had white spots all over the screen. Now after replacing the DLP chip we have no picture at all but we have sound. Help?
Likely you either forgot to reattach your color wheel ribbon connector, or have it on upside down. It's the tiny ribbon cable behind your circuit board that will come off as you pull the board away from the DLP chip.
Aug 18, 2012 | Mitsubishi WD-60735 Projection Television
Black verticle lines on our optoma EP1691
I just fixed mine at no cost! This problem is definitely with the DMD chip, but it may not need to be replaced. Try this first: 1. Carefully remove the lamp. 2. Remove the three screws from the bottom and the 3 black screws from in front of the housing near the lamp vents. 3. carefully remove the cover and using a spudger lift up on the black clamp lever holding I the ribbon cable to the system board. Set aside the cover. 4. When looking at the projector from the top with the lens facing away from you. The DMR chip board attaches to the main board on the left hand side of the main board just behind the lens. 5. If you press gently on the card edge connection on then main board for the DMR chip board, you may notice some slight movement. 6. Gently tighten the screw that holds down main board nearest the lens and closest to the DMR chip card edge connection. (I tighten all the screws holding in the main board as some of the them were quite loose from years of use.) 7. Put it all back together... When replacing the ribbon cable be careful not to jam it into the slot. Make sure the black clamp is up, and gently slide it in until it clicks a little. Put down the clamp. 8. Once all is back together... try it out. This fixed mine. No more black and white lines. I use my projector for outdoor movie nights mostly and my thought is that the DMR chip board became loose and some corrosion from the moist night air caused a bad connection on one of the card edge traces. Either the action of moving the card edge removed some of the corrosion and made a better connection, or the tightening of the screw caused a better connection. I hope you have the success I did.
Jan 23, 2012 | Optoma EP1691 Projector
Philips 60PP9200D went black and white.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixelation ,black and white picture,even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 05, 2010 | Philips 60PP9200D Television
There's a very narrow line (white) appears at the very top of the screen when the picture scene is mostly black. A verticle adjustment should fix it but where is it?? RCA F36TF720
it may be an electrolytic cap problem as most newer sets are controlled by an I.C. chip for horiz and vert timing/size/linerity
Nov 02, 2009 | RCA F36TF720 36" TV
I have a Sony KDFE50A10 50 inch HDTV When I turn it on for it has the lines verticle on it it takes a few minutes and then clears...tv or cable?
Hi,if its a an LCD RPTV it sounds like a light engine problem.Basically your tv uses 3 LCD chips that create the image .Each chip is like a tiny screen that blend together to get the colors and picture right.They are green,red and blue.When they start to fail you will start to get color discoloration or vertical lines.You will need to replace the light engine.God bless you!
Oct 20, 2009 | Sony KDFE50A10 50" HDTV
Verticle color lines on scanner bed and printout in photo mode
Hardware failure, nothing much can be done, just replace the scanner.
Aug 27, 2009 | Epson Expression 1640XL Graphic Arts...
While watch tv last night heard a crakle and we lost the picture on our samsung dpl tv. We got a new lamp and installed it. There is still no picture.
Sounds like the color wheel has shattered and the sensor is blocked by the peices. If the wheel was not blocked you would have a black and white picture.
Jul 06, 2009 | Televison & Video
LCD Screen
Replace the Ribbon Wire between the Mini DV unit and the lcd screen. Samsung wanted $136 to repair same issue for me. Screen started with colored lines eventually going to white lines and finally screen went completely black and stayed black. I replaced the Ribbon Wire after purchasing a copy of the systems schematics and repair manuel online. With total cost of everything i bought to make this repair I saved a little over $115 from what Samsung wanted for the same repair.
Jul 21, 2008 | Samsung SC-D353 Mini DV Digital Camcorder
DVD player - Picture goes from color to black and white
your problemens is in decodor of your tv its a proablem of service
May 06, 2007 | Toshiba MW24F51 24 in. TV/VCR/DVD Combo
Televison & Video Logo
83 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
