Vehicle won't start with remote or key.....wait a few minutes and car will start with a key
SOURCE: I live in Michigan. I
The remote start has has a status option for it to know when the car has started and for it to keep it running. Most techs do it the lazy way and just set the option to voltage sense. You have to have a tech hook up the tach wire to the remote start and then program it for tach sense.
SOURCE: Lost my remote viper remote
Common issue.
Open doorAlarm will be going offLocate the antenna (should be on the windshield)Find the little black push button on the antenna.Turn key to the ON/IGN position (where all lights are on)WITHIN 5 SECONDS push the black button 1 time and release (unless your installer changed the number of pushes it should be 1)Within seconds the alarm will ceaseStart your vehicle.
If any other issues, send me a message.
The car's computer wont let it start?
Well, if you changed the battery and the viper alarm is the issue; locate the push button valet/programming switch. Turn the ignition on, press and release the switch. The alarm will disarm and you can start the vehicle.
To put the alarm in valet, turn the ignition on then off, within 10 seconds press and release the valet switch. The LED will illuminate solid to show that the system is in valet.
