Battery drains 10x/times faster than it usually drained, this problem occurred right after I switched the device on after fully charging it whilst it was off.
SOURCE: correct procedure for charging battery
Batteries no longer have a memory problem so charge away. I plug mine in every night and have never had a issues.
SOURCE: Display brightness
Ok on your keyboard there should be some way to adjust the brightness just plug in the laptop and adjust it to what you want then unplug the laptop and adjust it to what you want and it should keep that setting. if that does not work you can check the bios settings some laptop bios' have a brightness option.
SOURCE: 86 cutlass wont start with
You may need a new starter, it could be drawing too much, or your fully charged battery is not a good battery. Have you load tested the battery?
SOURCE: My Garmin 1350 is fully charged. I used it
the software on garmin 1300 models is atleast 3.6/7 sounds like ur update didnt take, also check in settings see if you have a timer setting for sleep mode/stanby after x time
SOURCE: Acer Aspire 5738Z won't hold charge
Sorry. It seems that your battery is dead.
If your laptop is working fine on AC power only (with the battery disconnected), then your battery will need to be replaced.
