Bunn 10 Cup Home Coffee Brewer Logo
Cindy Miller Posted on Nov 13, 2015
Water and grounds running over before going into carafe
Padre Castens
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Nov 16, 2015
Padre Castens
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
8436
Points
10
Be sure the hole in the bottom of the filter basket is unobstructed. You may need to clear it or enlarge the hole if it isn't draining properly.
Slow dripping and ground cup is extremely hot
Have you tried cleaning your coffee maker? If not just fill half of the carafe with white vinegar and let it brew. Keep basket in during cleaning but no filter needed. After running the vinegar through the brew cycle, fill the carafe with plain water and run fresh water through about 3 to 4 times. I do this every 4 to 6 months. I have a light on my coffee maker that lets me know when I need to clean it. I hope this helps.
Cleaning the coffee maker
Cleaning a coffee maker is simple.
Fill the carafe with 9-10 cups of Water and 1 cup drain cleaner.
Put a paper filter in the basket. Run the cycle. You will see lots of garbage in the carafe. Repeat with the same water.
Next dump the water into the sink and refill the carafe with fresh water.
Run again, several times to flush out the acid. remove the basket and scrub it clean. Your coffee maker should run like new.
1helpful
How do I run the clean cycle?
I assume you mean descaling the coffee maker when the Clean indicator flashes after a brewing cycle. You can use a packaged descaling product or white vinegar. For the packaged descaling agent, follow the package directions for the ratio of product and water. If you are using vinegar, fill the carafe with a 50:50 mixture of water and vinegar.
Remove the water filter and remove any coffee and coffee filter from the brew basket. Make sure the unit is plugged in and turned on. Pour the descaling mix from the carafe into the water tank and then place the carafe in the coffee maker. You have 10 seconds to program the cleaning mode or the unit will return to the standby mode. The next step depends on the type of carafe. For a machine with the glass carafe, press Mode 6 times. Otherwise for a unit with the thermal carafe, press Mode 5 times. The Clean indicator will blink. Press Program/Set followed by the + or - button to select Clean On. Press and hold Program/Set until you hear the beep. Press Brew and wait for the cycle to complete (the Clean indicator will go off). Then do two brewing cycles with water but no coffee or coffee filter. Discard the fluid from the coffee maker from all three cycles. Wash the brew basket and then reinstall the water filter.
If you notice an odd taste to the coffee when you next brew some, do at least one more rinse with water (remove the water filter and coffee grounds/filter).
KitchenAid manuals are available from their site: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . The direct link to the manual for the Kitchenaid KCM223OB is http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10321647.pdf . See page 13 for the directions.
I hope this helps.
Coffee grounds in the coffee pot. It appears water does not flow into pot quickly enough, so filter basket overfills and causes grounds to go up and over the filter, then flow into pot. Also heat plate...
From what you described, it sounds like your carafe isn't fitting properly. The lid of the carafe is supposed to open a valve on the bottom of the filter basket. If this valve is clogged or not opening completely, that will produce your symptoms. Also, the warming element will not keep carafe hot if the carafe isn't sitting properly.
We recently purchased a refurbished Cuisinart DGB-600 Coffee Maker at a yard sale. So far, we've had three batches of horrible coffee that tastes more like water with coffee flavoring. The first two...
It sounds like the water isn't flowing through the coffee grounds correctly. Perhaps you don't have the right kind of filter installed (either the right-sized paper filter, or the "gold" filter that comes with the machine) ... or, if uising pre-ground coffee, and if the coffee is all in a pile in the middle of the basket... the water will follow the path of least resistance, so much of it may run "downhill" and around the coffee, through the filter and into the carafe, without passing through the coffee. (That would be more likely if you're brewing only a few cups rather than a full pot.) Or, you might not be using enough coffee; I would use about 7-8 tablespoons of ground coffee for 10 cups of water. I'd recommend getting it working properly with pre-ground coffee before trying the grinder. It's also important that the lid of the carafe is in place while brewing, and that the carafe is fully seated in its chamber; the bump on top of the carafe's lid triggers a spring-loaded mechansim on the bottom of the basket, which regulates the flow of water into the carafe... so if any parts of this system aren't lined-up right, you may get unexpected results (including, in some cases, water all over the countertop).
I also recall, once upon a time, using one of those pre-packaged "packets" of coffee... sort-of like a large tea bag full of coffee grounds... and getting unsatisfactory results; again, the water found it easier to run over/around the coffee packet, rather than through it.
I can hearing brewing noise, but no water filling the carafe
IF UNIT IT`S MORE THAN 4-5YRS BUY A NEW MODEL, U SAVE SOME MONEY FOR THE NEXT 5YRS
1helpful
2answers
Coffee overflowing and spilling out of the basket
Your coffee maker likely has the option where you can remove the carafe while it is brewing so that you can serve yourself in the middle of the brew. When you pull out the carafe in the middle of the brew, a small lever closes off the drip at the end of the basket (to keep the coffee from flowing onto the empty space where the carafe was on onto the burner).
Then when you replace the carafe, the lip of the carafe pushes against that lever and re-opens the valve so that the brew can now drip into the replaced carafe. Simple.
In your case, it appears that when you place the carafe onto the burner plate, it is not engaging that lever and opening up the valve; hence the valve stays closed and the brew fills over the basket and makes a mess, right?
So do this, pull out the carafe and look up where the pointed end of the basket drips into the carafe. You should see a lever, or plate that the carafe top lip hits when the carafe is placed into the burner plate. Once you find that lever, or plate, give it a push (like the carafe would) and see if it moves. if it does not, then that's your problem. It is stuck closed and won't allow the brew to exit the basket into the carafe. Clean it thoroughly if it is stuck and then see if works.
1helpful
Overflowing basket
The grind on your coffee is too fine, and if not there is too much coffee in the basket, hence the overflow.
2answers
Water is leaking from bottom of base.
I just had good luck pulling the grinder bottom piece forward while pulling directly up on the blade mechanism. Hope this helps.
Top Bunn Coffee Makers & Espresso Machines Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
