Apple iPad Air 9.7" 32 GB Wi-Fi Space Gray Tablet iOS 7, LCD Touchscreen, 2048x1536, 10 Hours Logo
A
Annette Dube Posted on Nov 13, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I do not know how to set keyboard. It seems the plug does not fit. I do not want to force it.
Mike M
Level 3:
  • Apple Master 3,349 Answers
  • Posted on Nov 13, 2015
 Mike M
Apple Master
Level 3:
Answers
3349
Questions
0
Helped
686172
Points
16707
The keyboard has to be USB or wireless BT.
Read the manual. Amazon com keyboard for apple ipad air
1helpful
3answers
The keyboard on my ONN android tablet is not working. I’m only able to use google voice. I went to setting and the tab for me to switch google voice is grayed out. Nothing seems to be working.
Go to the Google Play Store. Speak "keyboard" in the search. You should see an app for Google Keyboard 2-3 down. Make sure it is enabled. Once enabled you will be able to turn off Google Speech.
1helpful
I have an Apple IPad Pro. I bought a Bluetooth Keyboard Case from Amazon. I need to know how to get started. There doesn't seem to be an instruction manual. I'm in unknown territory.
It's fairly easy to set up usually. With the keyboard powered on there is usually a button that turns bluetooth on and a (usually) blue light will start flashing. At this point on the iPad you look in the bluetooth settings page and look for the keyboard to appear in the available devices. Tap the link to it and follow the instruction. The blue light should stop flashing and remain lit and the iPad BT settings will show that the keyboard is connected.
Keyboard won't let type and then disappears
I can't type on my device. Keyboard won't show ... ' T-Mobile Support
https://support.t-mobile.com/thread/48985?start=0...
T?Mobile US, Inc.Aug 11, 2013 - Please let us know because we want to make sure it's working for you. ... After opening the app I pressed "Force Stop" and then cleared the data. ... phone butthen i cant coz i cant type my password that is needed to reset it.
My Galaxy S3 won't let me enter text? - Android Forums at ...
forums.androidcentral.com > ... > Samsung Galaxy S3
Mar 10, 2013 - 25 posts - ‎15 authors
The keyboard comes up and does one of two thing: 1. it lets me type, suggests a word that I select & then doesn't place it into the text area OR it doesn't let me type .... Each character just kept disappearing as I typed the next. LG Keyboard has stopped
Jul 23, 2014
Samsung Galaxy S4 Keyboard can't remember added ...
Feb 21, 2014
keyboard disappearing while typing??
Jul 16, 2012
Digital Keyboard won't appear; ICS
Jul 15, 2012
More results from forums.androidcentral.com
HTC's Sense UI is Garbage: A Tale of D
I have the leather case with the keyboard but cannot attach to the android table that was sent
well thats strange,, the tablet has 1 USB 2.0 port and the keyboard connects to that port as its standard.. Its a standard port so all usb 2.0 connects for it is standard.
http://www.amazon.com/Coby-MID7015-Android-Internet-Touchscreen/dp/B0047Q9GT4#productDetails
and
http://www.amazon.com/Tablet-Stand-USB-Keyboard-Carrying/dp/B004OB0EBQ/ref=pd_bxgy_pc_img_y
is what u have right ??? try turning the connector around.. It should fit.
When setting up blackberry playbook for first time. it wont let me select a country on the agreement page
The Playbook attempts to download the license agreement from http://csbeta.websl.eval.blackberry.com/
and it seems this URL is no longer valid, as it returns
"Sorry! Nothing could be found here."
i figured the OS on my playbook is an early release so i'll be forcing an update.
to force an update, i fired up the latest desktop manager, completely turned off the playbook by pressing/holding the power button then clicking turn off, then i plugged it in..
desktop manager then shows an error message and gives you the option to update.. click that and leave it alone for an hour++ (depending on your internet connection)
i started the updated playbook, went through the setup wizard and this time when i selected the country, i got the license agreement and was able to continue.
option 2:
Kindle keyboard g3
Get a usb keyboards or a Bluetooth keyboard
1helpful
How to activate/use external keyboard with tablet
Try this Coby-related post, which I found... Directly quoted:
"The tablet is setup so that whenever you will be using the keyboard you will have to set it up! So with the machine on and the keyboard plugged into the tablet you select "settings" on the main screen. On the next screen you will need to scroll down to "Advanced Settings". On the next screen you will scroll down to "USB BUS MODE" and deselect the button removing the green check mark. You then select the Curved arrow on the side above the silver button wich backs you back out to the main screen. Now whenerver you open a screen requiring key imput you will be able to use the keyboard."
Need to fix AC adapter plug in
I'm trying to repair the same thing right now.
to get the case apart, the hangup screws are under the keyboard. to remove the keyboard, you must remove the small plastic (1"x8") strip that has the power button and indicator leds on it.
to remove it, go along the top of the keyboard, closest to the screen, there are 5 plastic tabs to be released, then pop only that side closest to the keyboard up, then, slowly work it around until it comes free. flip the keyboard towards you, and carefully remove its ribbon cable by first popping up the sockets (on the mb) retainer.
then you can get those last screws out and have at it.
peace!
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
