I replaced the fuser film after that paper is jam near fuser film
SOURCE: HP LASERJET 4250n PRINTER-PROBLEM WITH PAPER JAMS AND "FUSER ERROR"
Put a maintence kit in your machine, easy install, everything just clicks in, Every 200 000 prints it should be done, it includes the fuser, all feed rollers, sep pad and transfer roller.
These are great printing machine, they only ever need the MK and on this model a fuser drive gear wears and get noisy, but once that has been done once, it is ok from then on.
KIts seem expensive but they are meant to last 200 000 prints and usally do. These are one of the best most reliable printers in the market.
LINK to part info
SOURCE: hp 4250 paper jam erro
Is it a new or refurbished fuser? Where exactly does it jam. By trays, registration or before fuser? Problem can be with various sections. Need to know more.
SOURCE: Fuser Assembly damaged by user trying to remove paper jam.
This is one of those that is not quite so easy. I have uploaded the service manual for you. You may download it here.
Thanks and please take a moment to rate this solution as fixya as I have taken the time to upload the manual for you. Good luck!
SOURCE: Seems to jam in fuser, fuser has been replaced
if it always jams at the same place (fuser area) try another fuser or check the BLACK PLASTIC ASSY. THAT is mounted in the left door and takes the paper right after it comes out of the fuser ;part is called (PAPER DIVERTER) And sometimes one of the FLAPS That routes the paper is broken,hence causing paper jam.
SOURCE: hp lj m4345mfp printer showing 13.31.00 fuser
If you are using Windows:
Your values here will be the default values loaded when you click the print command in any programs in your computer.
Hope this helps. Please rate my response.
Thanks.
Have a good day
