SOURCE: digital signal
Hi.
You havent stated your make or model of tv set ?
http://dysonmanuals.llc.nu/
Chris..
SOURCE: Magnavox TV
If you use an antenna to get your signals...yes. If you have cable or satellite service....NO. None of your TV's have the new ATSC digital receivers, but cable or satellite don't need this.
SOURCE: trouble receiving local channels on TV using new Magnavox converter box
Your digital converter box probably does not have an analog pass through that allows the old analog channels to go through to the tv's analog tuner.
SOURCE: Is my Toshiba TV digital or analog?
if there is a label on the tv stating any of these words “Integrated Digital Tuner,” “Digital Tuner Built-In,” “Digital Receiver,” or “Digital Tuner,” “DTV,” “ATSC,” or “HDTV” then yes
if they say “Digital Monitor” or “HDTV Monitor,” or as “Digital Ready” or “HDTV Ready" then no
SOURCE: Magnavox converter box turns off
There is a setting I think might be causing this. My mom had this
and we went into the menu and details there is a spot in there that
says 2 hour, 4 hour shut down and we turned it to off. Just a thought. Hope it works.
