CASIO CALCULATOR, MODEL HR-150 TM
SOURCE: casio calculator HR 100 Tm
Printing models (except HR-8TE):
1. Have calculator in “print” mode
2. Press [CA]
3. Hold [SET/%] key for about 5 seconds
4. Input the tax rate
5. Press [TAX+]
6. Press [SET/%]
SOURCE: HOW TO INSTALL PAPER ROLL IN CASIO HR-8TM
There is a slot just in front of the printer
1. turn the power on
2. turn the switch to "PRINT" position
3. slot the paper in & press "FEED"
4. the paper should be able to feed up
SOURCE: loading paper tape
Well, I just had a long and vigerous fight withmy new HR-8TM. I came here and read all the before mentioned solutions. Then the idear struck me. Instead of cutting the paper even all the way across the roll, I cut it slanted on the sides and straight across the middle " __ " and guess what it passed the roller feed through.
It worked for me, maybe it will work for you.
SOURCE: Need Operation data to operate all functions of
how should i use if i want to use of limit in the calculator casio fx-9750G||
SOURCE: how do i change the
put calculator in print mode
press CA
hold % button for 5 seconds, release
put in tax amount with decimal point, press tax plus button
press % button
