CJ Finnie Posted on Nov 11, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My printer is not communicating with my computer it is with my phone thou.
Jerry Kramer
Level 3:
  • Office Equip... Master 3,933 Answers
  • Posted on Nov 11, 2015
Jerry Kramer
Level 3:
Answers
3933
Questions
Helped
882297
Points
12076
If it is communicating with your phone you are on a Blue Tooth connection. You most likely will have to hook up your computer by Blue Tooth as well. I don't know what type of printer you have but you may have an option to set up both types of connections but it will be in the printer menu under set up/wireless/network
1800246-7609 EPSON PRINTER TECH support phone number SV
i am correctly facing this type problem i found searching from goole and visit this site all problem solve just few minute thanks for this site. https://www.epsonprintersupport247.com/how-to-fix-epson-printer-not-activated-error-code-20/
What are the lyrics to: Holy Spirit Thou Art Welcome in This Place?
Holy Spirit Thou art welcome in this place
Omnipotent Father of Mercy and Grace
Lord in Thy presence there's healing divine
No other power can save Lord, but Thine
Fill all the hungry and empty within
Restore us, oh Father revive us again
How to print pic.s from i phone on epson printer
First of all, this only work if you have anetwork installed in your house; (modem, router and the correct configuration). Then your printer should be able to print wireless, in other words, a wireless printer. And last, the printer should be compatible with your iPhone. Apple devices are not compatible with most wireless printers, even thou they are working on it.
Where do i hook phone line on computer
Hi mp133, If the main goal is for your All-in-One Printer to communicate with your computer, the most common set-up is to use a USB Cable. Plug the phone line to your All-in-one-printer and then just connect a USB cable from your printer to your computer. I hope this helps. All the best to you. Good luck.
When I try to scan or print a message comes up telling me to ck power and usb connections. I have unplugged and restarted computer 4 times and still have problem
It could be a communications error message, the printer is not communicating with the computer.
  • Disconnect and then reconnect the USB cable.
  • Disconnect and then reconnect the printer power cable.
  • Restart the computer.
  • Remove and reinstall the printer software
  • If your printer does not function properly or communication error messages appear when using your printer, you can remove and reinstall the printer software.
    1. Click Start®Programs or All Programs®Dell Printers®Dell Photo AIO Printer 962®Uninstall Dell Photo AIO Printer 962.
    2. Follow the instructions on the computer screen to remove the printer software.
    3. Restart your computer before installing the software again.
    4. Insert the Drivers and Utilities CD, and then follow the instructions on the computer screen to install the software.
    If the installation screen does not appear:
      1. In Windows XP, click Start®My Computer.
    In Windows 2000, double-click My Computer from your desktop.
      1. Double-click the CD-ROM drive icon. If necessary, double-click setup.exe.
      2. When the printer software installation screen appears, click Install or Install Now.
      3. Follow the instructions on your screen to complete the installation.
    Communications error message
    The printer is not communicating with the computer.
    2answers
    Dell Color Printer 725 - Communication Not Available
    I have seen that in most of the cases (with lexmark and dell printers) it is fixed by reinstalling the printer software. Be sure that you completely remove the older drivers using the cd or using add/remove programs.
    6helpful
    Communication Error DELL 926 AIO Printer
    Found on another forum. For 926 this worked great.
    1. Go to Control Panel - Printers : Delete 926 printer
    2. Go to Control Panel - Programs and Features : Uninstall All Dell 926 related software. There should be 3 programs. (When prompted to restart, respond to wait.
    3. Rename Folder C:\WINDOWS\SYSTEM32\SPOOL\DRIVERS\W32x86 to W32X86OLD
    4. Now restart your computer
    5. Reinstall 926 Software.
    This worked terrific for me.
    Communication Errors with DELL AIO 926
    Well just try another cable for the connection between the printer & the computer... your can also check print spooler service under the services of the system....
    Lexmark x2500m printer do not communicate with Gateway laptop
    GAteway..not surprised. phone or email Gateway get some help..its the computer problem.
    X2250 not communicating
    will i think theirs two posible options why not communicate the printer first not proper installed the printer driver or maybe your connection from the computer to printer will loss contact that why not communicate...
    k24674
    ADMIN Andrew
    ADMIN Andrew
