Try removing the needle from the carburetor and soaking it in brake fluid (and any other parts that may look suspicious) over night; clean and regap or replace spark plug; ...also, try using high test fuel.... this runs cleaner on my Toro826.
Not being able to take pictures _at night_ likely has nothing to do with your SD card. If the SD card works during the day, it should be fine at night, too.
Any camera needs some light to take pictures. Many use flash to take night time pictures, or infra-red (IR) lighting. I don't know your camera well enough to know if you have either or how to configure how to turn that on.
Turn camera off take out battery's and sd card. Once everything is out put it to the on postion for about 2-3 min. Then put battery's back in with the camera being on still leave sd card out. Once it says no card turn camera off then put sd card back test in dark. If still not working call Moultire 8006533334 option 1 and 1 for a live person.
They are being saved to the internal memory of the camera. With no card in the camera, go into the menu and find "format" and follow the instructions to erase the internal memory. Insert your card and it should now work properly.
That doesnt mean that they have not been deleted after you looked at them this morning.
Remove the card and use a card reader to access the card to see ALL of the pictures currently on the card. This is like having a second opinion, both can't be wrong. The other aspect is that some pics are in memory and not on the SD card
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
This is because camera will show these pictures with specific file name/ number.
You need to check camera taken picture file name/ number and change uploaded file name/ numbers as camera firmware generate it.
Please change picture file name according to camera taken picture.
let me know if further help required.
