Samsung Galaxy Tab 3 SM-T210R 8 GB Tablet - 7" - Marvell Cortex A9 PXA986 1.20 GHz - White 1 GB RAM - Android 4.1 Jelly Bean - Slate - 1024 x 600 Multi-touch Screen Display - Bluetooth Logo
T
Therese E Ferriter Posted on Nov 10, 2015
Will not charge - has not been used in a very long time
sahani Arun
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on Nov 11, 2015
sahani Arun
Contributor
Level 1:
New Friend:
Answers
21
Questions
0
Helped
5775
Points
45
Use another charger
and put on charger for long duration
My tablet will not turn on or charge at all!
Are you using the supplied Samsung charger? Many times if your not using it, the tablet won't truly charge.
My kindle fire does not keep its charge. I can use it one time and during the ap it goes dead
If you charge the device fully, meaning 100%, and while using it with a simple app it doesn't last 2 hrs. then you need to replace the battery. Next time it goes dead, don't turn it on, instead plug the charger and let it charge to 100% while the device is off. Once is fully charge, use it as you would normally do. But still,it needs a new battery.
2answers
Kobo not accepting a charge
Lithium ION batteries are usually rechargeable. The use mode for these batteries is that there are a set number of recharges that equate to the life of the battery. Usually that life is approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the battery is used up, the maximum charge lessens which means where you may have had 8 hours of play time when the battery was new, you will only have 6 hours as the battery life is used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never recharge again or the max charge will be reduced to an insignificant amount of the original full charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries cannot have their batteries replaced.
Jul 28, 2014 • Kobo Arc
I have a nextbook 7 or 8 tablet. it no longer charges in any way, and it gets extremely warm when connected to a charger no mattet how short a time it is plugged in for.
My zpad won't hold a charge
Lithium ION batteries are useusally rechargeable. The use mode for these batteries is that there
used up.
Tablet wont charge
The charger has a function that restores the battery operation parameters by discharging then charging the battery a number of times. Refer to charging instructions in the pack but I think the cycle is a 3 hourly one, time to charge from a full discharge. If the charger thinks the battery is dead then it will try to recover the battery using this process. You may have left the charger on long enough to charge then also discharge the battery.
Start again and charge for the time in the instructions ONLY, if you are not sure of the time try it for an hour, then without disconnecting the charger turn the unit on and take particular note of any screen messages, if any.
You should be able to continue as normal now, but still be aware of the time you are leaving the charger connected for, as it may take some time before it returns to normal operation and stops trying to recover what it thinks is a dead battery.
Battery charing very slow, can't open tablet - won't turn on when button is pushed
The battery on the Asus does take a very long time to charge (over 12 hours before you use it the first time, then 8 hours or more each time). It takes even longer if you charge it from the USB port in a computer rather than connect it to its dedicated charger, or if you use it while it's charging. If you've already charged it for 8-12 hours, try turning it on by pressing the power button *and holding it down* for a couple of seconds before releasing it. Then, when using the tablet, try keeping it hooked up to the charger when possible, or at least recharge it overnight.
You can check on battery charge by tapping "Settings" at the bottom of the Home screen, then tap "Battery" in the Device category. The % charge will be at the top of the screen. I enjoy my Asus tablet, and it's good for several hours at a time between charges, but you do have to keep it charged up. Good luck!
Asus transformer T100T battery takes hours to charge & tablet won't turn on
So, greyhen2, we meet again. Here's the answer I gave to your other posting of this same question:
Top Samsung Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
