The tv screen does not light up when powering up I have a 52 inch Panasonic plasma tv that will only run the fans for a few seconds and shutdown red light blinks 10 times and repeats. I already have taken the fans off and cleaned thoroughly but the same problems continue. Can you help me solve this problem? is it a bad fuse on the motherboard? Also,The tv screen does not light up when powering up
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
