Home Logo
Connie McClain Posted on Nov 10, 2015
How do I install wax ring on toilet when no holes for bottom bolts?
3helpful
Leaking water at bottom centre both sides atbottom of base
turn off water to toilet,get a new wax ring,unbolt toilet,lift toilet off floor,scrape wax off floor and under toilet put down ring wax side up,set toilet,kneel on toilet not wobbling,put bolts back on,turn on water,if it sounds to hard,it is,call a plumber follow rays answer
Apr 13, 2015 • Home
How to install a toilet
Things needed; set of johnnie bolts, wax ring, water supply tube, open end wrenches.
insert the flat head of the johnnie bolts into the groove of the floor flange so the threads are pointed straight up. Install the wax ring directly onto the floor flange. Set your toilet bowl down on top of the wax ring so the johnnie bolts stick up through the holes at the bottom. Install the washers and nut to secure the toilet to the floor. Depending on the type of toilet, you may or may not need to manually install the tank to bowl gasket and tank to bowl bolts. Set tank onto bowl and tighten the bolts. Usually a 1/2" wrench. Do not over tighten because the porcelain will break. Install the water supply to the bottom of the tank and then tighten it to the water shutoff valve. Install the seat, and your all set.
Apr 09, 2014 • VitrA Home
Vitra
Install wax ring around base waste pipe. Make sure that 2 bolts are sticking out of a track under the toilet.Put toilet bolts through toilet holes and tighten nut with washer on each bolt to lock down the toilet. Now attache the water line that goes into toilet and bidet.
1helpful
Leak from the toilet every time it is flushed. It is a new toilet, flange, extender, and wax ring all installed 1 year ago.
Lift your toilet off again and replace the wax ring check the bottom of the toilet for cracks and make sure it is clean. Then install the toilet make sure to tighten flange bolts evenly DON'T OVER TIGHTEN. Try that to start with.
Feb 02, 2013 • Home
I wont to replace the sealant from around the tiolet waste pipe, what is the best way of doing this?
turn water supply off to toilet and disconnect water line from bottom of toilet tank. flush toilet to drain tank, use towel to soak up water inside that didnt flush.remove the 2 bolts ( 1 on each side of toilet), lift toilet up and move to one side and lay on it side, scrape off old wax ring from bottom of toilet, scrape off excess wax from pipe on floor. install new wax ring over drain pipe. stand toilet upright and lift straight up over drain hole and reset slowly to make sure each bolt goes through the holes on toilet, replace nuts and washers on toilet and tighten. hook water supply liune back up and turn on water.
Aug 30, 2011 • Home
3answers
Leaks at the closet flange and we tried many different wax rings.
Hello, W/D here. I always use the wax ring that has the plastic horn molded into it. Rarely, I will place another regular gasket on top of it if the closet flange sits too far above the floor or is cocked. The key to a good seal of a wax ring is to install it properly, and set it several times. What I do is tighten the bolts that bolt the toilet to the flange, and then sit on the seat, putting as much weight as I can on the bowl, and even wiggling a bit. The toilet settles, and I tighten the bolts (carefully) a bit more. I continue to do this several times until the toilet is settled well onto the closet flange and is secure. You have to take your time with this, and be very careful not to over tighten at any one time. You can break the closet flange or at worst, crack the porcelain bowl flange.
Best regards, --W/D--
2helpful
2answers
When the toilet is flushed water comes out from under the toilet bowl
The wax ring has gone bad. If the toilet moves when you set on it you might try snugging down the bowl bolts on both sides but be very careful not to go to tight you will brake the bowl.
If you decide to try to fix this your self with you buy a new wax ring buy the one with the horn in it they seal better.
Jan 31, 2011 • Home
My eljer tank cracked and I need to install a new tank. How do I just install a new tank? The bowl is fine. Companies are trying to charge me about $300 to do this and I do not have the money. Please...
Let's assume you can buy the tank.
Installation of tank is simple.
If you can buy the eljer tank, you can buy whole new toilet with bowl and tank from home center.
We'll walk through instructions for both options.
1) How to replace tank on existing bowl.
-Tank is attached from underneath with two nuts.
-Turn off water, and hold flush valve down to drain tank
-Water connection is one nut. Follow supply line up to where it connects to tank. Loosen the nut that is around supply line just underneath tank. Pull nut downward and notice a black rubber washer that is probably stuck inside nut, or is stuck at bottom of tank. Make a note of where that nut is because it seals the water line to tank.
-You might also have a flex connector instead of supply tube. In that case, just unscrew flex connect from bottom of flush valve.
-Look beneath the tank and there are two nuts that hold tank to bowl.
-Take off these two nuts. A ratchet and socket is best tool, but you can use crescent wrench. -Notice these nuts are not exceptionally tight, but they are firm.
-Straddle the bowl and hold tank with two hands and lift up. Tank will come right up.
-Notice that on bottom of the tank: there are 2 bolts sticking out and there is a spongy rubber washer. This is the spud washer. Your new tank will have new washer. This washer seals tank to bowl so water doesn't leak when you flush.
-Notice round opening where flush water flows into bowl. Spud washer seals this hole. If you have experienced slow flushing, or if you have hard water, pour several cupfuls of CLR Calcium Lime Rust into the hole. CLR is sold at Home Depot by the gallon for $10.
-Open box to new tank. Find spud washer and fix it to bottom of new tank.
-Now a new tank is slippery, I want you to set boxes on floor nearby so if tank starts slipping, aim toward a box instead of hard tile floor.
-New tank comes with 2 new bolts, with nuts. Look at instruction sheet and see exactly how they want you to connect bolts to tank. Look carefully where they want you to put washers. These washer seal the tank when you tighten bolts.
-Now your spud washer is in place, the bolts are attached to tank and are sticking out of bottom of tank.
-Straddle bowl and lower new tank into place. Make sure spud washer lines up. Bolts line up. And flush valve lines up with supply tube. It's that easy.
-Tighten the nuts. Remember, not too tight. Toilet is not steel. And you can tighten more if there is seeping water.
-Now tank is in place. Raise nut and washer that are on supply tube and tighten nut onto bottom of flush valve. This nut is fairly tight. You might want to buy a new washer.
-If you have a flex line for the water supply, then just connect the flex line.
-Turn water ON a little bit at a time to avoid gusher if something is not correct.
-Use paper towels to check for dripping or seepage beneath tank. Tighten nuts appropriately to end seepage.
-Flush toilet and look for seepage around spud washer.
-You're done.
2) How to install new toilet.
-Remove old tank as shown above.
-Bowl is held to floor with two nuts.
-Ideal world those two nuts come right off and you lift bowl up off the floor.
-Real world, those nuts are rusted and you have to drill through side of the nut and bolt to break it off.
-Lift bowl up.
-Have cardboard ready next to toilet so you can set bowl on something. Or set it in bathtub.
-Bowl will be damp and wax ring is on bottom of bowl and will mess up the floor.
-Notice how the toilet bolts are set in the floor flange. Take photo if needed so you can put it back. It's real simple, but if you have never done this, a photo might help.
-Take putty knife and scrape wax ring off of floor flange. You want it smooth, but you don't clean it.
-New toilet comes with wax ring and bolts, but you might have to buy these at hardware store. Get wax right with gasket. The boxes are marked. Buy two of them.
-Set wax ring in center of floor flange. Gasket goes downward. Rounded side of wax ring goes up.
-Set new toilet bolts into floor flange. Keep bolts straight up using wax from the old wax ring, or from 2nd wax right you purchased.
-Keep bolts straight across from each other.
-Time to set the toilet.
-Stand in front of bowl and grab on either side at point where seat connects.
-Here's the fun part.
-Bowl has to go straight down onto wax ring so you have to be strong enough to hold tank level while aligning tank with bolts, without knocking the bolts down. Like a carnival game.
-Straddle walk toilet while holding it up high enough so it will not knock over the bolts.
-Lower bowl into place going straight down using bolts as guide. Lower a little bit and check one side for alignment and then check other side until bowl is going down and bolts fit through the holes.
-If bolt falls over or gets pushed away, straddle walk toilet back and set bolt straight up again.
-Once bowl is aligned, keep pushing straight down on bowl, and finally use your weight to push bowl to floor. Be careful to keep bowl perpendicular to wall so tank will sit straight.
-Attach bowl to floor with nuts and washers.
-Install tank as shown above.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on toilet or any do-it-yourself project.
2answers
Leaking toilet
check the seal between the tank and the toilet.tighten it as necessary. (not to tight! you will crack the ceramic). Mkae sure the tank is square to the toilet.
also the water inlet connector.
2helpful
2answers
How to Install Toilet
It's not terribly complicated, assuming that by "install a new toilet" you mean where there was alredy an existing toilet. First, remove the old toilet. Shut off the water supply valve, and flush the toilet. Then use a spone to get rid of the water that remains in the tank. Remove the nuts on the two bolts at the base of the toilet where the toilet meets the floor. These are usually hidden under two plastic caps. Now gently rock the toilet until it comes away from the floor. Get help to carry it out. Clean up the old wax that's around the flange where the pipe disappears into the floor. Don't be a wuss, it's only wax. Now you'll need the new toilet, a new supply line, new mounting bolts (don't reuse the old ones) and a two wax rings. Yes, I said two wax rings. You'll see why in a minute. Assemble the new toilet according to the instructions provided. Now here's a warning: Do NOT overtighten the bolts the hod the tank to the bowl. You're dealing with ceramics here, don't break them. Now, put the new hold-down bolts in place on the flange. Read the insturctions that came with the toilet, but you have to do this NOW. Now you'll need a helper. With the toilet upsided down, unwrap a wax ring. Make sure it's room temprature or it won't seal. Press the wax ring around the outlet flange on the base of the toilet. Now you and your helper carefully turn the toilet over without crushing the wax ring. Lift the toilet and slowly lowe it so the wax ring is centered over the "flange" which is where the sewer pipe goes into the foor. Then press the toilet firmly in place. Now if you're like most people, you screwed up here and crushed the wax ring without being centered on the flange. That's why I told you to buy two. Now you know what not to do, scrape off the first one and start again. When you've got the toilet sealed on the flange, connect and tighten the nuts on the bolts. Now you may have to use a hacksaw to cut off the remaining ends of the bolts so you can get the neat little plastic caps to fit. Now connect the water supply line. Now's where you start praying. Turn on the water and let the tank fill. Check the supply line for leaks. Fix as necessary. Now flush. Is water running out from around the base of the toilet? No? Good, you got a good seal. Yes? Very bad. Time to go back to the home center for yet another wax ring. Repeat the sealing process and get a good seal this time.
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
