Where is the archos 504 RESET button
Bless you guys...!
I thook the chance n press the reset button....Nuthing has been erased from my hard drive!!! :D :D :D
Oh my gosh it worked! I had even called tech support at the company and they didn't even offer this solution. I even went as far as to buying a new battery at their suggestion. Thank you guys so much. You guys rock!
When turning on my Archos 504 I get the rocovery code 4 a then it says: Would you like to recovery it? I get three options:No-Repair-Format HD.No of them workt.The PC does not recognize the device either.
Disconnect the battery for few seconds, then press and hold the lock button for few seconds and, replace the battery and turn it on.
Thank you very useful i tried tried and gave up finallly press the reset button bingo it worked
You can hold down the on/off button for 10 seconds to turn off the archos. then turn it on again. this can be used to turn off the archos when it is not responding. Is this what you want?
I press the little gold bump. it worked. thank you so much
A better description of the reset button is that it is a round, gold color "bump" smaller than 1/4", almost flush with the circuit board. The solution by Guest was correct - push the button for 10 seconds then reinstall the battery and the unit should now work.
Take the battery off. Just beside the 4 battery terminal connectors there is a little button about 5 mm (1/4 "). Push it with the tip of a pen for 10 seconds and voila!! Hope this helps.
I don't seem to be getting any audio out of my archos. Everything else works but no audio. Would reset fix this? How do I reset?
SOURCE: Archos 504 RESET button
Hi - You can download the manual from the link underlined in blue below:
Archos 504
Se page 7:
Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: want to download direct to memory stick from archos 504?
You need the Archos Docking adaptor Gen 4 to do this.
SOURCE: i was given an archos but can't seem to figure out archos 504
You can download the manual from the manufacturer's web site at
http://www.archos.com/support/download/manuals/english_-_user_manual_-_archos_504-604_-_v2.2.pdf
yeah, but won't pressing the reset button clean up all the stuff i stored on the archos?
You guys are amazing. Solved my problem too!
