SOURCE: panasonic home theater sa-ht920
Although the Panasonic Home Theater systems are great when they work properly. If your machine displays the "f61" error message, it's likely to be little more than a paper weight for the average person. The inner workings of the machine are rather complex to disassemble for diagnostics. And can take several hours to check all the components. The best advice I can give you is to sell the machine on e-bay as a broken item. If you offer shipping you can get more money for a complete system (speakers & all).
SOURCE: F16 error occurs when trying to switch on DVD Home Cinema System
F16? I've seen F61. Usually an output IC problem, but it can be caused by a bad fan.
Remove the fan. Remove the sticker from the fan. Remove the small round piece of plastic (if it has one) from under the sticker. Put a couple of drops of oil or wd40 it it and spin the fan blades several times. Replace piece of plastic and sticker. Re-install the fan. Good Luck.
SOURCE: I have a Panasonic SA-HT650 Home Theater system
A power source problem. Means there is voltage measured at the output/speaker cable connections. Indicates a failure of the amp., or faulty power supply to it.
Just re-check all of your connections, especially speakers. And that the power ac power source from the wall is wired correctly and has proper voltage and grounding.
