Black watch engraved TGHK serial number AW 91-738
SOURCE: Is this a genuine Cartier serial number
is the watch real is it says cartier r1628 water resistant swiss made 2301 cc708177 ???
SOURCE: Set time on tghk watch
As there are no possible watch manuals for unknown brands, all I can say is:Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals.Go through all and you will find the right one, as all watches stand on globally accepted basics. It may take some time, but at the very end you will get what you want.Rate me, please
SOURCE: Need to set time on WalMart TGHK watch.
Use the Mode button to get to the time display. The seconds should be flashing. Then press the Reset button once and the Hours should flash. Use the ST/SP button to increment through the hours. When the hour is correct, press the Reset button again the get to the flashing minutes display. Go through these steps until all items are set the way you want them.
The alarm is done similarly by pressing the Mode button until the AL displayes and if in small font the ALM and/or CHI display next to the AL, you can turn them off by pressing the reset button until both are off. If you do want the Alarm and time set then leave ALM set but set the time using the reset button to get the hours flashing or minutes flashing and use the ST/SP to increment to hour/min you want. Finish the sequence by pressing the Mode button once. If the ALM or CHI are set, then in the Time display you will see the ALM and/or CHI indication next the day of the week.
