Behringer Xenyx X2442usb Usb Audio Mixer Logo
Rey Salazar Posted on Nov 08, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can i have the smpsu22 manual for my mixer
If i turn it on, the fuse is burn out
Kardoc
Level 3:
Top Expert:
  • Behringer Master 7,503 Answers
  • Posted on Feb 27, 2019
Kardoc
Behringer Master
Level 3:
Top Expert:
Answers
7503
Questions
0
Helped
2758971
Points
58323
Hobart A200 mixer is blowing the two fuses. There seems to be no insulation breakdown or short circuit. Replaced fuses, it will work for awhile then will blow both fuses. What should I be looking for
Question edited to add maker
Question moved from Cars and Trucks category.
chaffing in the wiring harness, or possibly windings on the motor. There is a dead short somewhere.
Service manual and wiring diagram.
A200 MIXER TECHNICAL MANUAL (ML-104858) (115/60/3)
Parts Town https://www.partstown.com > HOB-A200_spm PDF A200 Mixer 115/60/1 Technical ManualPage 2 of 43 ... Manual Bowl Lift ... If service is needed on this equipment, contact your local Hobart Service Office.
43 pages
https://www.google.com/search?q=hobart+a200+blows+fuses
My Russell Hobbs Hand Blender not working. It smells of burning, I suspect the fuse is burned. How do I removed the cover; there are no screw? Any help will be appreciated
Edited to Add;
The OP changed it from Hand Mixer to Hand Blender, so my information below only applies to a MIXER. She needs a new Stick Blender, you can't repair them.
No fuse in those, but there maybe a thermal fuse. If you smell burning, it will be the motor windings overheating.
Screws are probably hidden beneath the little rubber pads for setting it down when the beaters aren't in it. Having said that. many newer devices just have locking tabs. You need to use a 'spudger' and find the right place to press and twist. Often with Mixers, the carbon brushes to the motor stick, so a sharp tap will often get them running again.
1helpful
Kitchen aid mixer kg25hoxer repair manual
Manuals Literature
Kitchen Aid manuals link above
Sears link to manual below (may want to simply search with Google.com using the model name and number for parts if you plan to repair it yourself.)
KP26M1XSL5 KITCHENAID 6 QT STAND MIXER PROFESSIONAL 600 BOWL LIFT Manual...
Feb 26, 2018 • Food Mixers
Where is the jenn air mixer thermal cut out
Wonder if you checked the user manual on possible causes for not turning on. see page 10.
http://content.abt.com/documents/5384/JennAir-Mixer
Why can't my kitchen aid mixer turn n
Sounds like the worm gear was stripped. This gear is designed to fail when the load on the motor is too great. This protects the motor from overheating and burning out. By the way, the mixer should not be used above the number 2 speed when using the dough hook.
The worm gear is not all that hard to replace although you will have to contend with a lot of grease. See the Service Manual:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Motor turns but beater is not turning
The gear system contains a ceramic gear that is designed to break if if the gears are over stressed. This is to prevent the motor from burning out. Think of it as a mechanical fuse.
I would say you were kneading dough and broke the gear.
Don't stress, take it to a appliance repair shop and it can be easily fixed.
1helpful
2answers
I have a Pmp5000 889406987784 Eurowpower PMP5000 1200-Watt 20-Channel Mixer and Speaker Output A has no output. What has happened?
Usual problem is the Channel A amplifier has burned and blown the switching transistors. Usually an internal board arc occurs and unless very skilled at board work of clearing the burned area and replacing the components you are better to replace the HCA2400 amplifier module... about $160
1helpful
MUM 6622 Motor Has voltage to it but will not run!
I have the same problem after running for a while, turning off then back on. It will not start. I found the heat sink fuse in the motor was burning out. When the motor gets hot then turned off, no fan and the heat build up enough to melt the heat fuse. It would be an easy replacement if I could find where to get them. To find it on the motor, look at the wire going from one corner of the motor to another, but looks like it goes into the motor in between. Pull on that going into the motor to lift the heat fuse out.
3answers
Sunbeam 275 watt 2366 mixer
it is probably the swich /pot combination on the electronic board. The shaft on the unit I have had twisted off and would no longer turn the switch on or off.
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
