Are the zyxel pk5001z and the dlink n150 cloud router going to be compatable when i hook up my dcs930l & dcs 932l cloud cameras
Should be an easy task, you would just need to go through the manual, it's explained quite well. If you don't have the manual with you, then just download one from the internet: D-Link DCS 932L PDF Manual Download
SOURCE: dlink wireless router
make sure the Internet Protocol (TCP/IP) of your system is set to "Obtain an IP address automatically". to check, follow this steps:
On your desktop you have the icon "My Network Places", right click it then select Properties, then on "Local Area Netwok" right click again then select Properties, Then select the "Internet Protocol" then clcik "Properties" then select "Obtain an IP address automatically".
pls make sure also that the IP Address of your DSL Modem is not the same with the IP Address of your router. If in case they have the same IP Address, change first the IP address of your Router before connecting to your DSL Modem.
SOURCE: Really unstable Dlink dir-655 router
I would suggest you try to change the channel to a higher one and this solves this problem most of the times...You need to go to your router configuration to do that usually by opening a browser and type 192.168 ... and log in into your router...Hope this helps.
SOURCE: can anyone help me set up a dmz on this router(zyxel p 334)
Do you have a static IP to portforward with? i would not recommend DMZ because most routers lie - they still use a firewall even with DMZ.
SOURCE: unable to configure belkin n150 router manually
while connected to router, open internet browser and enter 192.168.2.1 into the address bar. this opens most belkin router setup utilities.
SOURCE: I have Belkin N150 Rouer.
f the modem light keeps blinking, it means that the router hasn't been configured yet. Also, rarely, it can be an issue with WAN port/modem port on the router or the ethernet cable connecting the modem to router or finally, modem may not be working as its not applicable in this case(as you said).
1.Connect comp.--(gray port) router (yellow port)--modem
2.On the computer, open the router page by typing 192.168.2.1 in the address bar of browser
NOTE : IF YOUR INTERNET SERVICE PROVIDER IS CABLE FOLLOW THE BELOW STEPS
3.Under Internet WAN , SELECT the connection type as Dynamic.->NEXT
4.On the far left column, click on "MAC address" under Internet WAN.
5.Click on clone and apply changes and finally check Internet status
6.If internet status > Not connected, we need to do a network power cycle
7.For this, unplug the power from router, then from modem, then unplug the coaxial cable from cable modem.
8. Wait for 60 sec, then connect the coaxial cable, then connect power to modem, wait for lights on modem to get steady, then finally, plug in the power to router.
Now, you may see proper lights lit on the router.
All my best wishes for a fast internet service through the router.
FOR PPPOE OR DSL CONNECTIONS
1.Under Internet WAN , SELECT the connection type as PPPOE ->NEXT
2.ENTER THE USERNAME & PASSWORD PROVIDED BY YOUR IN INTERNET SERVICE PROVIDER
3.CLICK ON APPLY CHANGES
For any advanced help, revert asap!
Thanks and regards,
MILAN
