Authentication
That means you probably don't have the password or the
Authentication Type set correctly.
For Windows XP below:
Click Start/Control Panel/Network Connections then Right Click on the Wireless
Network Connection and select Properties. When the Properties window open
click the Wireless Networks tab. Click on the SSID for your wireless
network that you connect to and the Properties window will open. You can
change the Authentication Type to match the type set in your wireless router
and you can also change your password or Network Key to make sure you have it
in correctly.
For Windows Vista below:
Click Start/Control Panel/Network and Sharing Center then look to the left of
the open window and click Manage Wireless Networks. Find the SSID of the
network that you connect to and double click it. When the window opens
click the Security tab to change the Security Type (which is the
Authentication), The Encryption Type and the Network Security Key (which is the
password).
For Windows 7 below:
Click Start/Control Panel/Network and Internet/Network and Sharing Center then
look to the left and select Manage Wireless Networks. Find the SSID of the
password).
in correctly.
password).
password).
Windows 7
1. Open Regional and Language Options by clicking the Start button, clicking Control Panel, clicking Clock, Language, and Region, and then clicking Regional and Language Options.
2. Click the Keyboards and Languages tab.
3. Under Display language, choose a language from the list, and then click OK.
Not hot hit the
Hit the tab key not hot.
