Watches Logo
Posted on Jul 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to set the time on Athletic Works watch
How to change from Military to regular time
Ekse
Level 3:
  • Master 13,435 Answers
  • Posted on Jul 13, 2009
Ekse
Master
Level 3:
Answers
13435
Questions
82
Helped
3983994
Points
38023
Press and hold the lap/reset button for at least 5 full seconds. You should see the word "SET" appear in the dispaly. Push the Mode button to change from alarm to date to month, time, etc.. Use the start/stop button to change the numbers.
1helpful
Can we have the instructions for this watch? Can’t see me to find online we and we can’t not do any d ungrateful with the new battery installed.
https://oureverydaylife.com/how-to-set-my-athletic-works-watch-12234179.html
No instructions are online for AW91-729 Walmart Athletic Works watch.
Article online that may help:
How to Set My Athletic Works Watch
by John Smith ; Updated September 28, 2017
Related Articles
How to Set Your Watch
How to Set Timex Watches
Freestyle Predator Watch Instructions
Swiss Military Watch Instructions
Wal-Mart sells affordable watches by the company Athletic Works. It's sometimes common to throw away the directions, only to discover later you can't figure out how to set the watch. The problem is that Athletic House doesn't have a website or any manual online, so you may have difficulty getting help unless you find someone who also has the watch.
There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
Press the start button to change minutes.
Press the reset button again to switch to hours. You will know it worked when the hour starts blinking instead of the minutes.
Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
Press the reset button to switch to the date, starting with the month, and press start to change it.
Press reset one last time to switch from month to the day, and again press the start button to switch days.
Press the mode button to finish the changes.
Tips
Depending on which type of Athletic House watch you have, the buttons might be in different places. But the steps remain the same, regardless of button placement. If you have more questions about your watch, bring it to Wal-Mart and ask to see a manual.
About the Author
John Smith began writing back in 2003. Smith is a technology writer currently living in Lansing, Mich. His articles have appeared in online publications including PC World and IGN, where he specializes in mobile apps for both Android and iOS. How to Set My Athletic Works Watch
Jan 29, 2018 • The Watches
To be able to change to analog time from military time
Go to your events/calendar. Click the little settings symbol there. Then uncheck 24-hour time and save. How do I change my clock settings from military time to regular time.
just found this on the internet dont no if this will help you out if not let me no.
How to change from military time to regular time
use the mode setting to change from 24 hr to 12hr
14helpful
2answers
I have an athletic works stopwatch. All it says on the front is chronograph. I bought it at Walmart. It has 3 buttons on the top and one on the bottom. I can't find the directions. I can't get it to...
I have the same Athletic Works stopwatch. I just figured out how to turn off the alarm: press either of the two mode buttons (middle top, or bottom right) until you see the regular time displayed (the seconds will be changing, but nothing else, and nothing will be flashing). Press and hold the reset button (top left); while holding down the reset button, press the start/stop button (top right). Watch the bell icon on the display in the upper right corner; with each press of the start/stop button you will see the bell either appear or disappear. When the bell disappears, release the reset button. The alarm is now off.
Apr 14, 2010 • Watches
8helpful
Athletic works watch that is stuck on military time
With my old watch (from Walmart), all i had to do was go into the time settings and cycle through the hours until it went past the military time's midnight and it would start going through "normal" AM/PM times.
I hope this is enough information.
Feb 15, 2010 • Watches
7helpful
How do i get my athletic watch off of military time? It's a water resistant watch up to 165 ft. model # aw60447w
military time:
1. When setting the time on your watch, IF you watch can change to Military time(and most can)
2. when you are adjusting the hours go through a full 24 hour cycle. You'll notice that the 2nd time through it is on military time.. 3rd time through back to 12 hour day AM/PM cycle .. 4th time back to Military.
So you can do this as many times as it takes to get to the right time ..
In 24 hour time you will see an "H" displayed where you normally see and "A" for AM and "P" for pm.
Sep 23, 2009 • Watches
7helpful
Athletic wrist watch stuck in 24 hour mode
Maddening, isn't it? Fortunately the solution is here:
http://www.ehow.com/how_5593310_set-athletic-works-watch.html
1 There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
2 Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
3 Press the start button to change minutes.
4 Press the reset button again to switch to hours.You will know it worked when the hour starts blinking instead of the minutes.
5 Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
Apr 30, 2009 • Watches
3helpful
Need manual/User Guide for an ''Athletic Works'' watch, model V403
Dave,
If you hold the reset button you will see the number 12 flashing with an H next to it this is for standard or military time. To change it press the st/stp button. To go forward press mode.Then it will ask for the year set that then press mode.Now the date change it just like the Hour and year.then day do the same.Now timeSet that the same and it should work!
Apr 26, 2009 • Watches
1helpful
I have a Athletic works watch and I can't get it off military time.
When in the set time mode press the A button this will toggle between standard and military time. I had the same problem, dscovered it by trial and error, not in instructions.
13helpful
4answers
With time displayed:
Press lower right, then upper left.
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
