Anonymous Posted on Nov 07, 2015
What is nvm password is xerox 5755
Please tell me how to increase print speed in xerox 5755 copier
Umair Qureshi
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 26, 2016
Umair Qureshi
Contributor
Level 1:
Answers
Questions
Helped
1639
Points
0
keyur patel
Level 1:
New Friend:
  • Posted on Dec 26, 2015
keyur patel
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1639
Points
Xerox 5755 prinnt quality low i mean print is light very tryng but print is a not set
Kindly provide solution of wavy print in xerox 5755.
Whatsapp 00923334298796
Dear All can any one tell me solution for this Error please XEROX 7228 Workcenter code 004-346 waiting for your kind replays
04.346, 04-562 Transfer Belt Home
The IBT Home Sensor does not detect the Belt Home signal.
If this fault is declared 3 times in succession, print mode will be disabled. In order to
clear this condition, reset NVM location IOT/Finisher 1221 to 0 in dC131.
5helpful
I have copier xerox 5021 error is 092-910 what does it mean
That error is an ATC failure. It can be caused by a bad drum or MCU Board. You can first try clear the value of NVM [752-059] (ATC Fail) or NVM [752-060] (ATC Fail Continuous Count) to '0'. Enter Diagnostics, Press and hold the [0] key on the Control Panel for 4 seconds or longer and then press
the [Start] button while keeping your finger on the [0] key.
Password is 6789. And go to NVM Initialize.
2answers
XEROX WC 5755 MACHINE ID ERROR
Xerox 5775 the folt is machine speed invalid error
How to increase ram
If printing speed is a problem only in PDF, RAM is unlikely to fix it...
Are other formats also slow, or what, please?
Best wishes,
Robbie
WHAT IS THE NVM RESET FUSER CODE FOR THE XEROX 7545 COPIER\
Have a look at the following link:
http://www.enxmag.com/2013_months/aug2013/WorkCentre7425StyleFaultCodeList_82013.htm
It has a list of fault codes and also tells you how to reset NVM counts. Look in the bottom right of the page for the instructions. Hope this helps.
My printer is xerox 1250, our problem is the color is not right. if i print red, the color change to pink. the yellow color is also very light. could you also tell me how how do the nvm value setting ...
Sorry to tell you this, but adjusting or performing maintenance on this machine is very, very dofficult unless you have the technical documentation and in some cases the specialized tools.
If you have a maintenance contract you should call the service department associated with that contract.
Any time the colors are light, be sure to check the amount of toner for that color and make sure there is plenty in the hopper. Also there is often an adjustment that you, ther operator, can make to increase or decrease the color saturation.
. If you are using a manufacturer of the toner other than Xerox, you might get some help with the agent that sold you the toner.
Otherwuse, it takes a trained technician with tools and documentation to keep the Xerox machine running properly.
System fault 9-357
the motor or gear driving your toner will be kaput. The nvm is just a datbase location that it refers to when it needs to know something. All that will do is run out your black developer (as no toner will be reaching it) Engineer is whats needed
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
