Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
E
Erik Valentin Posted on Nov 06, 2015
Wd-62725 tv was turning on but after a few it would tunr off to the point that now it does not. the power button does not light up
Ron Hoffman
Level 1:
New Friend:
  • Contributor 40 Answers
  • Posted on Jan 05, 2016
Ron Hoffman
Contributor
Level 1:
New Friend:
Answers
40
Questions
0
Helped
16052
Points
48
Indicates clogged filters or dust clogged fans. Clean and vacuum cooling fans and filters. Replace lamp assembly with new lamp. Should work fine. Also, try unplugging TV, wait ten minutes and plug it back in. The controller will reboot which may alleviate the problem. Regards.
5 Related Answers
Anonymous
  • 103 Answers
  • Posted on Apr 26, 2008
SOURCE: Mitsubishi WD-62725 constant blinking of green light
Check the lamp to see if it is damaged(this is in your owners manual for removal)If not please contact me for more info
Anonymous
  • 3 Answers
  • Posted on May 07, 2008
SOURCE: blinking green timer light
i have seen a couples mitsubishi and i all ready talked with a tech suport from mitsubishi but they said change the capacitors in the shop were i work we do the same but the tv still doing the same then we send the dm module to them and they fixed we asked whats the real problem and they said the capacitos the best i think is send the module to them
Anonymous
  • 927 Answers
  • Posted on Aug 05, 2008
SOURCE: I have a Mitsubishi WD-62725
Good Day, remicarlson;
This is not the easiest problem to solve. I will give some ways to troubleshoot you TV for today and for future.
I would though recommend that you seek an authorized service center to do this.
HERE ARE THE THINGS TO CHECK:
1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 uFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 uFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). I hope this was helpful. Good Luck, big IRISH.
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Oct 07, 2009
SOURCE: I have a rappid flashing green power light and the
You Can get the V26 Chassis DM repair kit at www.tvrepairworld.com which usually repairs that issue. The kit contains the parts and a CD with instructions.
Anonymous
  • 253 Answers
  • Posted on Apr 05, 2010
SOURCE: Mitsu WD-62725 green light blinking continuously.
pls check remote aur repair smps power supply of tv
Describe your WD-62725 62 in. Rear Projection HDTV-Ready Television Problem Green light is blinking the TV won't turn on. We've unplugged it and tried to push the reset button and the green light...
If the led light flashes green continuously, the fault came from the DM power supply. The faulty parts there are the electrolytic capacitors. Let me know if your handy with electronics and I will assist you to fix it yourself.
Jdvillanueva
I have a wd 62725 mitsubishi digital tv. the timer light keeps blinking fast and cant turn on the tv nor watch it what could be the problem
Try pressing power button for 10 seconds or until it turns off. Wait for 1 minute and turn it on again.
BTW, I own a 73 inch model.
2helpful
Tv modle wd-62725 after power outage timer light blinks constantly and will not power on even after trying system reset
what do i do when this problem occurs ive already tryed to do the reset button but that didnt help at all?
I have a Mitsubishi WD-62725 that I purchased in February 2005. The manufacture date is November 2004. I was watching a DVD the other day and all of a sudden the picture just went black. I never received a...
It sounds Lamp got broken inside, please take out lamp from TV and check its glass tube. If found broken, replace it.
Lamp replacement procedure is written in user manual page-95, click HERE to download user manual copy if required.
Lamp is available in Part Store.
Thanks.
2answers
2answers
WD-62725 Need to reset to start
Good Day;
When TV will not turn on press the menu & input buttons on TV's panel, hold for 5 seconds. Count the blinks, eg; blinks 2 then pauses then blinks again. It should do this 3 times.l With that information respond back.Or the d-board is bad.
Good Luck.
2helpful
2answers
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
