Pitco Frialator SG14 Deep Fryer Logo
R
Robert Lutchman Posted on Nov 05, 2015
Takes an hour or more to start on mornings
The oil is cool the ignitor works and the pilot is lit but the chambers take forever to flame up
1 Related Answer
Anonymous
  • Posted on Feb 13, 2008
SOURCE: Pilot light won't stay lit
Wrong voltage thermocouple? must have 400mv, residential uses 25-40mv.
2answers
Why wont the pilot light on my hot water tank stay lit
there is no pilot- it is lit with a ignitor. If you have problems the unit needs a service cleaning of the flame sensor rods.
Lighting pilot light on kitchenaid dryer
It is all automatic, when you press start the power is sent to the gas assembly (if the timer is set for heat). The power originates from the cord to the timer to the temp control (on the blower housing) to the fuse next to the control, and to the gas assembly. The solenoids ignitor and flame sensor are all energized at once. The solenoids cannot release the gas unless the ignitor drops out of the circuit. That is the job of the flame sensor. Once the sensors bi-metal bends and opens the circuit, no more power goes to the ignitor< hoever, once the ignitor is glowing it generats a signal and becomes a thermogenerator with holds open the solenoid (holding coil) If for some reason the gas did not ignite the glow coil will cool off and shut down the solenoid. So what can go wrong? Lint buildup in the blower housing cause the fuse to melt. No power can be sent to the gas assembly. The flame sensor is open and not allowing power to the ignitor, the ignitor is open and not glowing. Old timey dryers had a pilot light. You hold down on the red lever and light the flame. Then release the lever and the pilot stays lit. I doubt if yours has a standing pilot. How modern gas dryer work:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
Hi, got old Eurolec Gas oven/hob. Hob lights up fine. Was cooking in oven all morning, no probs. Tried to light oven for evening meal & gas will not stay lit, goes out once ignitor & temp' dial...
Hi, your thermocouple is faulty, it is the little probe like thingy that sticks up into the pilot flame. It is there for safety purposes, detects flame and holds a valve open magnetically to allow the gas to pass through. Try giving it a clean with a scourer, sometimes works, or your pilot flame is not big enough, could be low on gas or unit needs a service Kristian KJ Tech
1helpful
Pilot light is lit both on oven and stove top... previous user says to turn on gas and lite "sensor" or "2nd pilot" it stays lit as long as oven knob is on but oven burner does not light. "sensor" goes out...
On standing pilot ovens the maker uses a safety device to kill the gas in case the pilot blows out. As long as the pilot is lit the gas safety magnet hold the gas flap open inside the safety valve.To save energy the pilot has 2 flames. The standby pilot keeps the cooper/nickel probe/sensor warm so the oven will light faster, the 2nd pilot is much larger, only appears when the oven control is turned on and this is what opens that valve. So when you turn the oven knob on the gas leaves the control and goes downtown to burner land. If that pilot is lit and that slow opening flap inside that valve is open, then the gas will enter the burner tube and ignite when it hits the pilot. Pretty slick ain't it? So what can go wrong? With age the flap inside the safety valve will wear out, get weak, work a little, then take forever to light and eventually just goes bye bye. When you get ready to replace the valve it ain't gonna be adjusted exactamundo, you gotta tweak it. To do so after bubble testing for leaks and lighting the pilot you turn it on and observe the flames. It needs to be not more than half way up the flame spreader. If it is to small of a flame it will take forever to bake even a pie shell, if it is too much their could be burned bottom and in some cases fire hazards. OOPs.
Kenmore gas dryer #110.97282100 won't heat. what part do i need?
Your easiest (cheapest) starting point is with the thermistor (flame sensor).
You can easily check that it is in direct contact with the pilot... and at the same time - check the ignitor is sparking
1. Check for ignition - if not igniting - replace ignitor.
2. Check/clean Flame sensor - if pilot is lit - replace the sensor.
3. If voltage at the gas valve checks out (from flame sensor) - gas valve should be replaced.
CLICK HERE to see the available parts if one of them is not working properly.
Wall mounted CBN30T, pilot goes out
IF its balance flue it could be blocked . Burner or orifice blocked lack of air to pilot slightly blocked thermocouple defective .
2helpful
2answers
The oven pilot does not light. The broiler will not work. The only thing that does is the light. GE XL44 range. The burners light and the pilots stay lit.
    If you have standing pilots, make sure the pilot for the oven/broiler is lit as well.  When you turn the thermostat up to call for heat, you should see the pilot get larger. That larger pilot flame heats a hydraulic sensor and opens the main burner valve.
    1helpful
    Problem with oven is it takes hours to reach temp
    temp. sensor isnt working you would have to call in a repairman
    2helpful
    Furnace pilot is on, pilot ignitor continues to click, no main flame
    sounds like the sensing bar on the spark ignition is dirty.....a wire brush works nicely.
    1helpful
    Reddy heater model 28725
    propane heater uses a hot surface ignitor. this operates off 120 volts and glows red/orange when actuated. it stays lit throughout the heater on operation.  on the backplate of the combustion chamber is a high limit with two wires coming off it.  these two wires connect to the spade connectors on the flame detector cappillary.  Once you establish a fire, the flame detector generates a 750 millivolt signal which is applied to the pilot/main valve assembly.  My diagram will show this. 1fa8284.jpg
    Top Pitco Frialator Kitchen Appliances - Others Experts
    Paul Carew
    ADMIN Andrew
    ADMIN Andrew
    Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
