Question about Nostalgia Electrics RIC-100 Retro Series Portable Ice Cube Maker
The ice cube size are not normal at any size setting. the sizes are odd shaped and small. what could be wrong?
What is the ideal size of an ice cream scoop?
I think the ideal size of a ice cream scoop is 8.2 X 1.8 X 1 Inches.I am using oxo ice cream scoop.There are more details about ideal ice cream scoop.
Jun 03, 2018 | Ice Cream Makers
Is there a pipe in the top box of a ice cream machine
it is called a feed tube but it depends on the type of unit you have and they vary in size.
Sep 06, 2014 | Taylor Ice Cream Makers
I need parts list
spec for belting - size and mesurement
Jul 11, 2010 | SaniServ 401 20 Quart Ice Cream Maker
Ice-cream maker doesn't fit together
Do a 1/2 to 2/3 batch. Put a book and a soup can on top of the mixing arm to keep it down.
The machine does make wonderful Ice cream, however it is noisy and fiddly. Do not try the full batch as it just doesn't work. I find doing 2 half size batches works best. Also find a spare room to run the noisy beast in.
Jun 16, 2009 | Cuisinart ICE-50BC 1.5 Quart Ice Cream...
Replacement lids for Salton Jars
I don't know the exact size you need, but for that kind of thing I go to Uline. They seem to have almost everything that no one else does. Their minimum order may be more than you want, though. http://www.uline.com/
Jun 11, 2009 | Salton Ice Cream Makers
My tub is warped!
You may find just what you need by looking around at Thrift shops , recycle centers , 2nd hand fix it shop. all of these places have lots of odds an ends. ,You ll find it there. I all ways do. Good luck DFD
Apr 15, 2009 | Rival 8550-X 5 Quart Ice Cream Maker
No accumulation of ice
Check to see if your condensor coil is clean, use an air compressor or other source to blow thourgh the coil,dont just brush it off. newer refrigerant charged systems need as much air flow as possible to work ,also make sure the cover is on the condensor section while the ubit is in nrmal operation. try setting the cube size to lowest setting and let run for 24 hrs. Let me know if you need further assistance.
Nov 16, 2008 | Ice Cream Makers
Nostalgia Electrics RIC-100 Retro Series Portable Ice Cube Maker Logo
232 people viewed this question
Top Nostalgia Electrics Ice Cream Makers Experts
Tom Chichester
Bill Boyd
Are you a Nostalgia Electrics Ice Cream Maker Expert? Answer questions, earn points and help others
