I have Emerson LF501EM5F TV ( 50 inch LED). It suddenly went off and does not switch on now. When i plug it back, It is making beeping sound.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Hi.. thanks for your response.. The Main board you are referring to, is it the power Board or the board with all external ports ?
Main board and power board are different. The main board is one that has all the external connections to be connected. Like AV in/out, HDMI etc: It is otherwise called as the main digital board.
Where can I buy a power board
SOURCE: i have a 19 inch
More than the tv power supply board have problems in this tv,don't know yet.But the whinning sound,the power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.First must see how it turn out.
SOURCE: My 50 inch emerson tv just turned off and now is
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
SOURCE: I have a 50 inch emerson led hdmi tv and it makes
You have a bad power switch, it's two that you have to replace the one connected to the remote sensor and one connected to the manual switch parts are reasonable but labor to put them on can cost.
It has bad capacitors if you can unplug it and take off the back cover and look at the capacitors! just google bad caps and you will see what a cap is and what they look like bad and good!
SOURCE: changing fuse on a 50 nice emerson LF501EM5F
If fuse should blow out, there should be sufficient reason. Without rectifying it, never replace a fuse. It might lead to more faults to occur. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
