Doxa Ant-magnetique Large 8-day Pocket Watch Logo
g
george pugh Posted on Nov 04, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When was doxa watch made case serial number 1172819
Black enamel dial arabic numbers.a minute dial on left side of main dial.2 dust covers on back with serial number 1172819 on each cover
Mister Danger
Level 3:
  • Master 5,631 Answers
  • Posted on Nov 04, 2015
Mister Danger
Master
Level 3:
Answers
5631
Questions
0
Helped
1198973
Points
47629
You should ask an antiquary or a good pawn shop. Or do a search in abay sometimes they have similar vintage stuff
Pulsar v800-5050 serial number Grey pinstripe dial rectangle gold coloured case black leather strap I bought this watch in Australia in 1990 and sadly lost it 2002. Iv been looking for one since and...
Being 1990 model, it is obsolete.
Pulsar are a company that manufacture lower end products.
Possibly there are none left working now due to the age.
Look on fleabay or gumtree there may be someone selling an old one.
tip
HOW DO I SET MY DIGITAL -- (PUSH BUTTON) -- WATCH
mcdevito75 here, The Quartz Mechanism is made in such a way, that the battery"s electricity changes in a way, while going thru the Quartz and thus Display"s the Numbers and or Letters on the Dial or Display, By PRESSING these Various Buttons, you are Changeing the Battery"s Voltage thru the Quartz and thus Displaying the Numbers and or Letters. ---------- Genarally, you need worry about only TWO (2) of these Buttons to SET your DIGITAL (push button) Watch, They are the MODE and SET Buttons. ------------- The MODE Button is usually on the Right side of the caseing, PRESS this Button, depending on your watch you may have to hold down this MODE Button 2--3 seconds, once you see the Dial Or Display BLINKING you are set to RE--SET your watch, NOW, PRESS the SET Button, usually on the LEFT side of the caseing to change each Function (Hour, Minute Etc.) once each Function is SET, PRESS the MODE Button to move onto the next Function. ------ Once all the Functions are SET, PRESS MODE again to see a STEADY Display or Dial. ---- It May take a little practice so be patient. ------ Some DIGITAL watches may not have a MODE BUTTON, But Rather a DIMPLE on the watch caseing you would PUSH in with a PIN or Tooth Pick, same MODE and SET procedures would apply. --------- Use your watches name plus .com online to obtain a user manual or look for a small watch repair shop in your area to order a NEW owners manual for your watch.
on Jul 10, 2010 • Watches
tip
Watch glossary: F
FLANGE
The usually inclined ring that separates the crystal from the dial. The flange is sometimes equipped with features such as tachymetric scales and pulsometers.
FLINQUé
Engraving on the dial or case of a watch, covered with an enamel layer.
FLUTED
Said of surfaces worked with thin parallel grooves, mostly on dials or case bezels.
FLY-BACK
Feature combined with chronograph functions, that allows a new measurement starting from zero (and interrupting a measuring already under way) by pressing down a single pusher, i.e. without stopping, zeroing and restarting the whole mechanism. Originally, this function was developed to meet the needs of air forces.
FOLD-OVER CLASP
Hinged and jointed element, normally of the same material as the one used for the case. It allows easy fastening of the bracelet on the wrist. Often provided with a snap-in locking device, sometimes with an additional clip or push-piece.
FOURTH WHEEL
The seconds wheel in going-train.
FREQUENCY, see also vibration
Generally defined as the number of cycles per time unit; in horology it is the number of oscillations of a balance every two seconds or of its vibrations per second. For practical purposes, frequency is expressed in vibrations per hour (vph).
FUSEE
A conical part with a spiral groove on which a chain or cord attached to the barrel is wound. Its purpose is to equalize the driving power transmitted to the train.
on Jan 11, 2010 • Watches
3answers
Where is the serial number on a guess watch
if you can't see it on the back, it's probably inside the back cover.
Hello please help, I wish to know what year Rolex Oyster Perpetual Lady Date model 6519 was Manufactured. Thank you in advance.
This model Rolex has been manufactured over multiple years, and it is not possible to date your watch based purely on is model number. However, it is possible to date most Rolexes based on their serial numbers, which can be found stamped between the lower lugs (i.e., the lugs below 6:00 on the watch dial). You will need to remove the band from these lugs to read the serial number.
Dating the watch case of a Rolex does not necessarily date the entire watch. It is possible that a movement from another watch was placed into a watch case that is younger or older than the the movement. Like Rolex watch cases, Rolex movements can also be dated by their serial numbers, if this is a concern you have about this particular watch.
This jeweler has put together a nice summary of when Rolex watch models were introduced and which serial numbers are associated with specific years of manufacture. Once you have found your serial number, this should help you date your watch. I have no connection (financial or otherwise) with this web site, but I found the information useful and presented in an easy to understand way.
http://www.bgrayjewelers.com/rolex_information.htm
Jun 03, 2011 • Watches
What do the number on the back of the Geneve Diamond ladies watch mean.
There may be three number on the back of a watch.
1) The case number.
2) the movement number.
3) the serial number for the case +watch assembly.
8helpful
3answers
How do I find my serial number on my bulova watch
Serial numbers are generally on the back of the watch.
You may be able to find two or three numbers on the watch.
A case number, a movement number and a serial number.Alternatively you might find a style number (which in your case is 26B44) and a serial number.
5helpful
Have a waltham pocket watch in an illinois case enameled dial with a recessed seconds dial at bottom with a numeric 6. seconds on face also. can't find year or pic of this watch
If you go to the web site "www.antique-pocket-watch.com/waltham-pocket-watch.html", you will find information about Waltham watches and if you read the serial number off the movement (open the back and read it off the back plate), you may be able to find out the year of manufacture.
My citizen watch number came out from dial. Please
To gain access to the face of a watch removing it from its case and is best left to a professional, since there can be unexpected difficulties.
Replacing the back seems to cause difficulties since care is needed to maintain the moisture seal.
2answers
I have a Benrus watch from the early years I'm guessing, can't get into the gears to find the serial number, the model number on the back is 247712. The second hand, which is just a round dial, came out of...
It would be very easy to mess up the watch by trying to replace it yourself. The part you are working with is very delicate and can end up costing you much more in additional parts and repairs. The repair is easy enough that you should be able to go to a local watch maker/technician and have it be fast and inexpensive.
Sep 19, 2009 • Watches
Top Doxa Watches Experts
john h
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Doxa Watch Expert? Answer questions, earn points and help others
