Apple iPhone Smartphone Logo
Posted on Nov 04, 2015
THE IOS SOFT. DEV. PACK IS BY I-EKB - Apple iPhone Smartphone
Whatsapp for my samsung wave gt s8500
Hi if u have a android market on your phone then u can simply go in to that and find your whatsapp on there and install it
Upload Files Dev Files Cloud
tip
Wii soft mod guide
Wii SoftMod Guide 3.1 - 4.1
Before we start into the process, you will need an SD card, at most 2gb capacity. This SD card will need to be formatted into FAT32 format.
Note: If you are on Wii System Firware 3.1, 3.3 or 3.4 You need to be connected to the Internet, unless you know the proper steps to upgrade using the Wii System WAD and Firware Updater 4.1 which I may include later.
First, download this file pack. Wii SoftMod 3.1 - 4.1 Pack
Download Readme file here. Wii SoftMod Readme
Step 1. Install The Homebrew Channel & BootMii
1. Put all the files from ‘Wii SoftMod 3.1 - 4.1.rar’ onto the root of the SD Card.
2. Insert the SD card into Wii.
3. Go to Wii Options, then go to Data Management > Channels > SD Card, then you will get a message saying "Load boot.elf?" , select 'Yes' and the Hackmii installer will run. (Goto the Channels first, then insert card or your console might freeze)
4. Install Bootmii as boot2 if you can, if not then install it as an IOS then go back and install the Homebrew Channel.
Step 2. Install Recommended CIOS
1. Go to Homebrew channel and run Trucha Bug Restorer, load IOS36, press 1, read the warnings then select 'downgrade IOS15', select to load IOS from SD card then let it do its job, keep an eye on what it is doing and make sure you select 'load from sd card' when it asks & don't get any errors.
2. Run Trucha Bug Restorer again, this time select to load IOS15 on first screen using dpad left/right, then select the IOS36 menu & install patched (select 'yes' on all 3 patches) IOS36 to slot 36, again using IOS from SD card.
3. Run Trucha Bug Restorer again, load IOS36 and this time select restore IOS15.
4. Run cIOS38 r14 installer, select IOS36 as the one it should use and then select wad install.
5. If your Homebrew Channel flips upside down then continue with the guide and when completed reinstall the homebrew channel.
Step 3. Update System Menu (Only for 3.1, 3.3 or 3.4 Firmware) Note: Internet Connection needed
1. Before you update to 4.1 make sure you have at least 250 blocks free or you will brick, install IOS60-patched first with Wad Manager using IOS249, then run Firmware Updater 4.1.
Step 4. The Final Step
1. Go to the Homebrew Channel and run Wad Manager 1.4 and load IOS249 (Default) and SD card.
2. Instal the following IOS.
* IOS38-64-v3610
* IOS50-64-v4889
* IOS53-64-v5149
* IOS55-64-v5149
* NeoGamma r8b17
Restart your console and your finished!
Jailbreak iphone3
Google "RedSn0w" for details and instructions there is a group called dev team that can help you
Please send me to my email a software for jailbreaking iphone 4 ios 5.0.1
please download this program and run it.Than click to jailbreak. https://sites.google.com/a/iphone-dev.com/files/home/redsn0w_win_0.9.10b5.zip?attredirects=0&d=1
Feb 05, 2012 • iPhone Apps
1helpful
Is it possible to access the whole C drive when using Ubuntu?
What Can Be Mounted
The most common thing to be mounted is a hard drive partition. Hard drives are kept in /dev and have different names depending on what type of drive they are. IDE/ATA drives are labelled as /dev/hda, /dev/hdb, /dev/hdc and /dev/hdd (since a PC's IDE interfaces can only handle 4 devices at a time). Note that these can be devices such as IDE/ATA CDROMS, Compact Flash to IDE converters, and some special floppy drives (although they tend to appear mainly in laptops). For SCSI devices the labels are /dev/sda, /dev/sdb, /dev/sdc, /dev/sdd, /dev/sde, /dev/sdf, /dev/sdg, /dev/sdh and /dev/sdi (since a SCSI chain can contain up to nine devices). Other types of drive, such as USB, SATA, etc. are mapped to these SCSI devices by Linux. Therefore SATA and USB drives are labelled as /dev/sdX where X is a letter, starting at "a".
Since these are literally the devices you can issue a command such as:
sudo eject /dev/hdc
If /dev/hdc is a CD drive then it will eject.
In the case of hard drives, there is another abstraction. A hard drive (and many devices such as USB "sticks" which act like hard drives) can be partitioned to allow many filesystems to be stored on them. This means that the filesystems themselves are accessible via the partition labels, such as /dev/hda1 (the first partition on /dev/hda). This means that we finally know about something we can mount, a partition, since it contains a filesystem.
Another physical filesystem which can be mounted is the ISO9660 filesystem used on CDROMs. Since there is only ever one CD in a CD drive there is no point creating /dev/hdc1 (where /dev/hdc is a CDROM drive) since there is only one filesystem on it. That means that you can mount CD drive devices explicitly, so if /dev/hdc is a CDROM drive then it is possible to mount /dev/hdc if there is a disc in it.
Floppy disks only contain one filesystem, and are labeled as /dev/fd0 for the first drive, /dev/fd1 for the second drive, etc. So now we know three things which can be mounted.
Devices like USB sticks are treated like hard drives (so /dev/sda1, for example, may contain a filesystem) and so are iPods (although I think the main data on an iPod is stored on the second partition)
Mounting is not restricted to physical devices. If you have a filesystem "image" (which IS a filesystem, whether an exact copy of an existing filesystem, or a filesystem created specifically for that file) then you can mount that through the use of a fake device called the "loopback device"
How To Mount/Unmount Filesystems
Unmounting
Firstly I will tell you how to unmount any filesystem you mount after trying these commands. Unmounting is done through the "umount" command, which can be given a device or a mount point so:
sudo umount /mnt
sudo umount /dev/hda1
Would both unmount the filesystem on /dev/hda1 if it is mounted on /mnt.
Remember that a filesystem cannot be in use when it is unmounted, otherwise umount will give an error. If you know it is safe to unmount a filesystem you can use:
sudo umount -l /mountpoint
2answers
Can anyone point me to the Manual and driver for the EKB-3000. I contacted ORtek and they sent me a ftp://61.218.39.140:1000/Driver/EKB-3000.zip and it DONT work. HELP...
Here is ORtek EKB-3000 Manual:
ftp://61.218.39.140:1000/Manual/EKB-3000%20Manual.pdf
And here is ORtek EKB-3000 Driver:
Both links working 100%
Unable to install turboc++ in new mother board with 2.0 dual core
If I were you, I'd use dev-c++ or MS Visual C++ exprees, both are freely available on the Internet and are excellent IDE's for programming in C++.
Dev-C++: http://www.bloodshed.net/devcpp.html
Visual C++: http://www.microsoft.com/express/vc/
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
