Question about Weather Channel WS-8500TWC-IT Wireless Temperature Station with Wireless Solar Powered Outdoor Sensor
Why does outdoor temperature display only show = signs?
Everything else works.
    Top Expert:
  • Weather Channel Master
  • 53,133 Answers
The outdoor sensor probably uses solar energy to charge a battery that powers the wireless transmitter. The battery may be defective or the charging circuit may have failed. The instructions that came with the station could provide some troubleshooting tips.
Posted on Nov 04, 2015
SOURCE:
I have a model 9125itc thermometer. The outdoor temperature is not showing on neither indoor or outdoor instruments. all I am getting are - - bars. I have installed new batteries
  • Remove all batteries
  • Install batteries in outdoor unit and allow time for it to begin transmitting temperature data
  • Install batteries in indoor unit. You should see outdoor temperature displayed. If not, the outdoor unit may be defective
Dec 23, 2017 | Measuring Tools & Sensors
My outdoor compressor won't kick on and thermostat is not showing current temperature
sounds like a bad tstat. turn power off to indoor unit, put the red green and yellow together with a wire nut at the tstat in order to bypass and turn power back on. if EVERYTHING works you have a bad Tstat.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Oct 09, 2017 | Heating & Cooling
Just put new batteries in both units but can't get the oudoor temp to show - what have ee done wrong?
Replacement has to be done in a certain order.
  • Install batteries in outdoor unit. Allow time for unit to initialize and begin transmitting temp.
You may find that the outdoor temperature is not transmitted in very cold weather. Right now it is below freezing and my indoor unit is showing - - for outdoor temperature.
Dec 13, 2016 | Measuring Tools & Sensors
Why isn't outdoor temperature displayed on indoor unit?
I have a La Crosse unit right in front of me and it is showing +18 F tonight. Saturday, we are supposedly going to sub-zero.
With regard to your problem, La Crosse instructions are very specific about the battery replacement procedure. Remove all batteries from both units, then install new batteries in the outdoor unit. Allow time for the outdoor unit to "initialize" and begin sending temperature data. Install new batteries in the indoor unit and you should see the outdoor temperature displayed.
Feb 12, 2016 | La Crosse Technology Wireless Temperature...
Radio Shack 63-1090 indoor/outdoor temperature unit. Won't give outdoor readings. Temps are cold, -5F but it always worked before. Put in new batteries in the inside and outside units, wiped outdoor sensor...
According to instructions for similar systems, you have to replace batteries in the outdoor unit first, then the indoor unit and wait 10 minutes without pressing any buttons for the indoor unit to begin displaying the outdoor temperature.
Dec 31, 2013 | Heating & Cooling
Lacrossetechnology
Hi Susuan,
One of these methods below should get your device working properly. Good luck!
LaCorosse Tech Support email address.
The product information page
From the manual:
915MHz RECEPTION CHECK FOR OUTDOOR TEMPERATURE SENSOR
The atomic clock will receive the temperature data within 3 minutes. If the temperature data is not being received 3 minutes after setting up (the display shows "- - -"), then please check the following points:
1. The distance of the atomic clock or outdoor temperature sensor should be at least 6 feet (2meters) away from any interfering sources such as computer monitors or TV sets.
2. Avoid placing the receiver onto or in the immediate proximity of metal window frames.
3. Using other electrical products such as headphones or speakers operating on the same signal frequency (915MHz) may prevent correct signal transmission and reception.
4. Neighbors using electrical devices operating on the 915MHz signal frequency can also cause interference.
Note:
When the 915 MHz signal is received correctly, do not re-open the battery cover of either the outdoor temperature sensor or atomic clock, as the batteries may spring free from the contacts and force a false reset. Should this happen accidentally then reset all units (see Setting up above) otherwise transmission problems may occur.
The maximum transmission range is 330 feet (100 meters) from the outdoor temperature sensor to the atomic clock (in open space). However, this depends on the surrounding environment and interference levels. If no reception is possible despite the observation of these factors, all system units have to be reset (see Setting up).
May 24, 2013 | La Crosse Technology Ws-8418u-it Atomic...
Medion md41199 atomic clock, cannot get the outdoor temp to show, how to fix please
Remove ALL batteries in transmitter AND clock.
Insert new batteries in outdoor transmitter.
Insert new batteries in the (receiver) clock.
Wait until outdoor temperature is received AND displayed on clock BEFORE setting time/date/etc.
Mar 11, 2013 | Audio Players & Recorders
The wireless transmitter doesn't work
Mine quits working when the batteries in the outdoor part need changed .
Dec 15, 2017 | Centrios Audio Players & Recorders
3M Precision Digital Atomic Wall / Desk Clock with Indoor & Outdoor Temperature and Alarm will not display outdoor temp, i have replaced batteries, outdoor sensor is transmitting, does not appear to...
After replacing the transmitter batteries several times, I tried replacing the clock batteries. They must have been getting low. Once I put in new batteries in the clock it worked fine. Good Luck.
Aug 30, 2008 | SkyScan 86742 Digital Atomic Wall Clock
Weather Channel WS-8500TWC-IT Wireless Temperature Station with Wireless Solar Powered Outdoor Sensor Logo
517 people viewed this question
Top Weather Channel Measuring Tools & Sensors Experts
john h
Andrew Taylor
Andrew Taylor
Are you a Weather Channel Measuring Tool and Sensor Expert? Answer questions, earn points and help others
