Whirlpool LER4634J Electric Dryer Logo
T
Theresa Ryan Posted on Nov 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool electric dryer will not start when start knob is pushed
Dryer is 6 years old purchased July 8,2009 at Loews it's a Whirlpool. It has 3 choices to dry with High, casual and delicate. When the push to start button is pushed the dryer will not start.
Charlotte Sharp
Level 2:
Habit-Forming:
  • Expert 144 Answers
  • Posted on Nov 03, 2015
Charlotte Sharp
Expert
Level 2:
Habit-Forming:
Answers
144
Questions
0
Helped
29684
Points
371
First check beaker flip it off than back on next check the door switch if tab missing or loose it should spring back when pressed next the dryer may have over heated the thermal fuse may have blown
Whirlpool duet electric dryer leaking water
Check and clean your venting from the dryer to the outside. If it is plugged it will trap the moisture in the machine. Remember heat doesn't dry the clothes without air flow to push the moisture out.
4answers
Whirlpool Duet GEW9250 Dryer; Only Running in Delicate Cycle
that knob is actually a switch. fixing it will be much easier, if you replace the whole switch unit..
good luck..
Electric will not start, vent discharge is clean any ideas?
purchased new clothes dryer. The old one was 6 years old
2answers
Dryer wont start - no lights
Dryer door does not think it is closed. There is a sensor on the top of the door that is probably not making contact with the door. Trying pushing the top part of the door and holding it then press the start button.. if the unit starts running then you know what it is. I just had one of these dryers delivered today and had to find out about this by myself tonight!!
35helpful
2answers
Whirlpool cabrio steam electric dryer has sensor light on and does not work
have a problem with my cabrio dryer its powered on but when i push start the sense like comes on and does nother whats the problem
Whirlpool Electric Dryer wont turn on
Try this;
In your browser bar type in youtube.com
In the search box type in repairing whirlpool dryers
Then click on the apprpiate video.
This should help you.
Plz rate my solution.
Thanks.
2answers
I have a whirlpool duet washer and dryer the dryer lights all come on but I get a beeping sound and dryer will not start
try to unplug the dryer for 5-10 minutes this should reset the board. if not take off the bottom panel and test the resistance of the thermistor ( the tech sheet is in the bottom there or up top)
Whirlpool dryer does not start and beeps.......
Same problem here, however I can assist the start by rotating the drum while pushing start. May be a capacitor problem???
Dryer problem
the door switch is bad. $16.65 Item #
528948 at repairclinic.com
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
