Re: Bought a used camper, but it did not come with a...
What brand of camper is it? Is the company still in business? If so, look them up on the internet at see if they have a manual listed, most likely it will be under "customer support", or give them a call and order one.
the vehicle will be a normal workshop manual for the make the camper will be a problem but check with the camper service agents as they may have copies on disc or in hard copy
USING YOUR LP GAS SYSTEM AT LOW TEMPERATURES . ...... The detector is powered by the 12-volt DC system and is always powered as long as the camper is ...Do not block the tailpipes or situate the vehicle in a place where the exhaust ...... as familiar with your camper as you are with your own personal car or truck.
? 1:57
https://www.youtube.com/watch?v=3RAVBoYX5S0
Sep 11, 2008 - Uploaded by hammerdownauto
The best times I've got with this old truck, fuel tank, tool box and all was in the high 15's. .... The engine I'm using 60 years old and the car body is 40 years old. ... I used a generic propaneregulator and 12 volt air solenoid valve. ... just curious what you think this does to the o2 sensors as far as gas / air mix ...
Is it a slide in camper? and if so there should be jacks that go at the 4 corners above the truck box. you lift the camper up slightly and drive the truck out from under the camper. The jacks could have been removed and stored in the camper under a bench seet in the dinett.
As I recall, your Axiom has a Tow Rating of 5000 pounds -- but check your Owner's Manual to be sure. I have several friends who tow with their Isuzus (using 1st and 2nd Gen model Troopers and Rodeos) and pull pop-up campers, high-profile campers, ATV trailers, etc... There's even even one guy who pulls his Trail Rig (another Isusu) to various off-road events on an 18-foot tandem axle steel frame trailer -- All of them do so without any problem whatsoever. The thing is, all of them use a Load Distributing Hitch System, such as this: http://www.truckaddons.com/Catalog/subpages/hidden-hitch-weight-distributing-hitch-systems.htm It makes a HUGE difference. Hope this helps.
