Televison & Video Logo
k
kenny williams Posted on Nov 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tv comes on for a few seconds then starts to blink on screen then cuts off with red light on stays on
Just got replacement light
NoName Jack
Level 3:
  • Mitsubishi Master 1,150 Answers
  • Posted on Nov 03, 2015
NoName Jack
Mitsubishi Master
Level 3:
Answers
1150
Questions
Helped
232583
Points
4657
Hi Kenny
Being a projection device... Which most TV's aren't ...
You need to break the fault down into the Projection Section or the TV Section.
Or Power Supply Section
Projector bulb blown, overheating etc.
Power supply sensing overload or fault then automatically shutting down.
TV Section may be OK
small internal LCD screen is projected by lens.
Check internals.
Happy Troubleshooting
8helpful
My hitachi plasma tv model: p55t551 every time i
turn tv on the red power light comes on then goes off again
My KDF-42WE655 will not turn on . The green start up light comes on and I can barely see the tv come on . After a few seconds the red light starts blinking and does not stop. The screen never comes on ....
Hello! When was the last time you replace lamp in your TV? If long time ago (2+ years) - replace the lamp. If red light blinks in sequence (example 4 flashes, pause, 4 flushes, pause and so on) - then I need to know how many flushes between pauses. It is an error code. If it blinks just constantly - it is a bad lamp. Regards. Russ.
2answers
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Red blinking light on tv?
unplug tv overnight. if that doesnt work the powersupply is probably bad.
1helpful
Sony KDF-46E2000 - Screen Goes Blank
The lamp can cause the picture to cycle without spitting out a lamp error. I'd replace the lamp and clean out the dust/dirt from fans, etc to hopefully resolve your issues.
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
