Eaton Power-ware 5110 UPS
If you have power going to it and lights etc. then its probably just need the battery replacing, refer to your manual about replacing them, its normally a very easy job on most models, make sure before you start though that you have disconnected the power.
Maybe an idea to take the batteries out anyway before you order them, put a meter across and see the voltage, if they are 12v then you should be looking for over 12.5v if its under 8 then they are most definably shot
Here is link to Power ware batteries
Exide Powerware UPS battery
Check and flip the reset button
if it still is faulty have it repaired or replaced
