Reports missing file t8ExtPEx.dll
SOURCE: Problems with Internet Explorer 7
The reason for that sometimes is the system of your computer is blocking the site or the page you had requested.........but mostly specially if the posted link is too old, their's a possibility that the page that you have requested has been deleted or remove from the url,website,etc. or the link has only limited time on the page that you tried to view in a new window.
Therefore, the link is deleted and you can't view it in a new window any longer.
I hope i have help you........and by the way, pls rate this solution acording to it's benefits, specially if it works...thank you!
SOURCE: Sometimes when I click on
Its looking the registry error in ur system so do a registry repair scan with Intel software partner Reg In Out registry cleaner
SOURCE: what is the dll file which is used in internet
Hi User
The Dll file used in opening the internet explorer is ieproxy.dll
In order to register the dll file ,follow the steps
1.Click start and Run
2.In the Run type Cmd and click OK
3.In the command prompt type regsvr32 ieproxy.dll and press enter
4.Click ok
Thanks and regards
Aboobacker s
SOURCE: I am unable to open internet explorer ,Internet
Hi User,
Follow the steps below to resolve your issue with internet explorer
1. Go to Control panel --- Add or Remove Program
2. Search for anything Veoh Web player or Toolbar
3.Remove the Veoh Webplayer and restart the internet explorer
Thanks and regards
Aboobackers
Testimonial: "Worked just Fine ,Great Work "
SOURCE: WHY IS NEW TAB BLANK WHITE PAGE?
Very possible the page is simply set to default blank page. I assume you are able to surf to some other web page without issue? If so surf to the page you want as your default and then go to your browser options page and change the default home page setting to that page.
