Cell Phones Logo
A
Anonymous Posted on Nov 01, 2015
How do i set the time on a pantech p5000? - Pantech Cell Phones
Erin Wood
Level 3:
  • Master 652 Answers
  • Posted on Nov 02, 2015
Erin Wood
Master
Level 3:
Answers
652
Questions
0
Helped
211082
Points
2583
Date and Time Settings Pantech Marauder
Date and Time Settings - Pantech Marauder™ [Device-Specific Instructions]
  1. From a home screen, select Apps (located in the lower-right).
  2. Select Settings.
  3. If applicable, select System (appears in Starter mode only).
  4. From the SYSTEM section, select Date & time.
  5. To use network-provided values, select the following:
    Enabled when a check mark is present.
    • Automatic date & time
    • Automatic time zone
  6. If not using network-provided values, perform the following to adjust date & time manually:
    1. Select Set date.
    2. Adjust the date then select Set.
    3. Select Set time.
    4. Adjust the time then select Set.
    5. Select Select time zone.
    6. Select the time zone.
  7. Select Use 24-hour format to enable of disable.
  8. To change the date format:
    1. Select Choose date format.
    2. Select one of the following:
      • Regional (6/7/2013)
      • 06/07/2013
      • 07/06/2013
      • 2013/06/07
Pantech P7000 outgoing texts are dated yesterday. Fix?
Check the date setting and the AM/ PM on the time setting.
tip
Nikon CoolPix P5000
Good day,<br /><br />It sometimes happen that you lose your cameras user manual.<br />This can be very frustrating as you need to look up something, but you can't seem to find a manual anywhere!<br /><br />Well if you follow <a href="http://www.retrevo.com/s/Nikon-P5000-Digital-Cameras-review-manual/id/1074dj693/t/1-2/">THIS </a>link you can download your cameras user manual on your computer and thus keep a digital copy handy for all the times you need it.<br /><br />Please let me know if this information was helpful!<br /><br />Kind Regards
1helpful
How do I set the time and date on a Pantech cell phone?
Here is the manual: https://www.att.com/support_static_files/manuals/Pantech_Ease.pdf
Most phones, in settings, allows you to chose to set the time manually or "use system time" (it may be called network time or similar). If you choose to allow the network to set the time, it will take what AT&T has and update your phone.
1helpful
Pantech user manual
http://bit.ly/K74fpu
It's the third link, Change the ringtone
How do I change the time on Pantech Swift?
Setting the time & date
1. Tap Menu; > Settings > Phone.
2. Tap Time & Date.
3. Change Time, Time Format, Date, Date Format or Auto Update > Save.
Cheap unlocking codes
Get the Cheap unlocking codes for any Brand like Apple, Samsung, ZTE, Huawei or any other Brand.
Unlock Your Cellphone Use Any Network in The World
https://www.unlockninja.com/
2answers
Pantech link II unlock
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Nikon P500 baterry drain
The biggest drain on batteries by this type of camera is because the screen is on all the time.
Somewhere in the menu options should be either a screen saver mode or operation timer that can be set to turn-off after a choice of minutes duration you choose.
1helpful
2answers
My pantech all of a sudden has the wrong date and time on it how do I correct it ?
Go to settings then cliq on time and date settings, then set it to the normal time then cliq OK. Thank you for using Fixya.
Top Pantech Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
