SOURCE: install alarm system
Battery- RED RED (+) IGNITION SWITCH HARNESS (2 CONST WIRES)
Ignition 1- PINK (+) IGNITION SWITCH HARNESS
Starter 1- YELLOW (+) IGNITION SWITCH HARNESS
All Door Trigger- WHITE (-) SMALL HARNESS BELOW ASHTRAY
Trunk Trigger- RED/BLACK (-) AT TRUNK LIGHT
Parking Lights- BROWN (+) BEHIND FUSEBOX UNDER CONSOLE OR SWITCH
Power Unlock- WHITE (+) POSITIVE TRIGGER OR DRIVERS KICK PANEL
PowerLock- LIGHT BLUE (+) IN CENTER CONSOLE "BEHIND FUSEBOX"
SOURCE: need to pair the remote with the alarm
If you know where your Valet switch is, turn the ignition on, push and release the valet switch once, then push and hold it, you should hear the siren chirp once, then while still holding the valet switch, push the #1 button on the remote, you should hear the siren chirp again. it is now programed. If you have the package that came with the remote, it should have a table on the back that tells you how many pushes of the valet for which feature you want to program. Most remotes are one push for all features, some are 7 or 8 pushes. So if it say auto learn is 7, turn the key on, push it 7 times, the push it again and hold it, the push #1 button, and it's programed. Hope this helps. If all else fails, take it to your nearest best buy, if they charge you to program it, it won't be much.
