Vehicle Parts & Accessories Logo
Elvitor Defe Posted on Oct 31, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How program crimestopper control CHX433TX of 6 buttons
Derrick Schultz
Level 3:
Top Expert:
  • Vehicle Part... Master 11,405 Answers
  • Posted on Jan 29, 2019
Derrick Schultz
Level 3:
Top Expert:
Answers
11405
Questions
0
Helped
2331333
Points
23972
Hello
u will find a lot of wiring diagrams and circuit diagrams help books and stuff like this .. im a frequent buyer there since Im a mechanic so take help from there
1 Related Answer
Anonymous
  • Posted on Mar 07, 2011
SOURCE: How to program a crimestopper remote control model
To program this remote-
1) Open hood or ground GREY wire @ pin #7 on 12 pin connector coming from Crimestopper control module usually located under dash.
2) Turn key to on position.
3) Press red programming button coming from module 4 times, after a few seconds the parking lights on vehicle should flash 4 times.
4) Press button #1 pause, #2 pause, #3 pause, #4 pause on the remote you are programming, the lights should flash after ever button push. After all four codes (buttons) are learned, the unit will exit code learning mode. If not, turn off key and close hood. Hope this helps......BUZZ
How program crime stopper remote control # CHX433TX of 6 buttons
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u
U can also get free manuals
Hi: I have a crimestopper sp300 my old LCD remote was broken so I order a new one but I can set up because is not a override bottom on the main device,I want to know what's the right valet swicht wire...
Most valet switches are just a simple normally-open momentary push button like this:
http://www.radioshack.com/product/index.jsp?productId=2062508
1helpful
2answers
How to program a crimestopper remote control model #chx433tx
How is the chirping sound turned off?
1. Open Hood (ground blue hood pin wire if no hood pin switch is installed)
2. Turn Key to the ON position
3. Press program / valet button 5 times, after a few seconds the unit will flash the lights 5 times.
4. Push the valet/program button 18 times. You must get a light flash after each button press.
5. Press the LOCK button to turn chirp confirmation off.
6. Turn Ignition OFF, Close hood (or unground blue hood pin wire) and check for changed features.
Chx433tx owners manual
I need to reprogram my chx433tx remote
1helpful
Deactivated remote start system
you can find the manual for your unit at www.crimestopper.com but first you have to look under the dash and get the actual model number from the unit the go to www.crimestopper.com go to support choose manuals and manuals again then locate your model number from under your dash to get the correct manual you should be able to print it out and then you may take it somewhere you can also contact crime stopper tech support at 800.998.6880 ext 210
Ezee start remote stopped working
if you have the manuals look under transmitter programming. if not go to crimestopper.com and look under manuals and you can download one from there and follow the steps into reprogramming the transmitter.
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
