Cars & Trucks Logo
Connie Cassidy Posted on Oct 31, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My fitbit charge gets stuck on the finishing up step.
The battery was dead for a couple of days. When I tried to restart it, it gets stuck.
Rich Laue
Level 1:
New Friend:
  • Contributor 26 Answers
  • Posted on Nov 02, 2015
Rich Laue
Contributor
Level 1:
New Friend:
Answers
26
Questions
0
Helped
54701
Points
27
To reset the charge stick it in its charger, make sure harbor is charging then hold the bottun until it vibrates.
Claude Kayser
Level 3:
Top Expert:
  • Cars & Trucks Master 9,098 Answers
  • Posted on Oct 31, 2015
Claude Kayser
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5065387
Points
28436
I'm having trouble setting up my tracker using ... - Fitbit Help
help.fitbit.com/.../en.../I-m-having-troubles-setting-up-my-tracker
FitbitJul 31, 2015 - I'm having trouble setting up my tracker using my computer ... If you followed the steps in How do I set up my Fitbit tracker on a computer? and couldn't complete ... Your tracker is charged. ... Or, if you'd prefer to get in touch:.
2002 S430 key stuck in the ignition and transmission stuck in drive
the battery is dead
cures
  1. charge the battery using a battery charger
  2. or the 4 ends of battery cable loose or rusty clean them.
  3. alternator dead or its wires busted/loose or fuse blow to it
  4. jumper cable crank it off 2nd car, or call AAA tow for a JUMP.
  5. check ALL FUSES, skip none.
  6. borrow a charged battery?
  7. then scan the PCM once battery reads about 12.6vdc rested.
  8. 10vdc at battery is hard fail or less. all brains go mad. this.
  9. I bet you made the alternator die but is easy fix. if did. fuse blow to ALT. never do fender work near any alternator unless battery Neg lug is pulled all shops know that, and do not let them weld on your car ever unless you ask how first or boom happens and thin wallet next.
I purchased a Fitbit Versa a couple of months ago and it was great for a couple of weeks. Then the battery started lasting only 12 hours. Now it is completely dead an will not take a charge.
very easy just go to reliable-store it has all manuals
there many other websites also but in this matter this website is too good
1helpful
1helpful
2answers
05 Cadillac SRX battery draining down after a couple days of sitting.
Dealer should have been able to figure this one out!
Best bet to trouble shoot is next time it is going to sit for a couple of days disconnect the battery. After the couple of days pass hook up the battery and if it's dead then the battery isn't holding a charge, if not then something in the vehicle is draining the battery.
If you live in a colder climate weak batteries tend to be more of a problem as temps get colder.
If the battery is more then 3 years old it is a prime suspect.
Hope this helps!
Hello ... My 2004 Hyundai Elantra GLS is having major electrical issues. For the past few days, the radio has periodically "skipped" (i.e. shut off for a second and restarted), the interior...
Better check the battery as it sure sounds like its dead. The charging system could be at fault also A brand new battery can run down and need a charge if the charging system isnt doing its job Hope this helps you .Good luck!
Battery light came on a couple of days ago. Last night it started and as it was going the radio stopped working and the engine was reving as if stuck in 2nd gear. After shutting off the van it would not...
problem on battery light came on, loose belt tension. power is out so all part will not work. and check the battery again, make sure it was fully charge.
Battery goes dead after a couple days. was told it could be anti-lock break module...how hard and expensive are these to replace
Your battery going dead every couple days has absolutly nothing to do with your anti-lock break module. (unless it is causing a short or something and staying on-which i doubt.) Have you ever thought that maybe the battery may be dead and old and need replacing. you should test to see how strong the battery is first with a volt meter or load tester. batterys go dead all the time- more so this time of year where it starts to get cold out. If your battery is new or just got it. (usuaslly 2 or 3 years you should be fine). - it may be your alternator isnt charging the battery anymore. Make sure all dome lights are off when the doors are closed. or that nothing else is left on
GMC not starting
dead battery that should be charged overnight with external charger.
also check your clamps-clean and repair damaged battery terminals
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
