Tablets & eReaders Logo
A
Anonymous Posted on Oct 31, 2015
How do i log on to my tablet if you forget the password?my tablet is a rca7 voyager
I tried typing in my passqord and it said it was wrong and tried shutting it off the hole way
My tablet does not connect to our WiFi. The number is there
press your router name go to forget click on that then it will re search for wifi router click on your router name type password then connect you might have type the password in wrong
Can't connect to WiFi connects but says saved
You need to press the "forget" button the next time you try to connect, and then let the tablet find the router again.
You apparently have tried and not entered the proper password, and now when you try to connect it is still going to wrong password.
Once you press "forget" it will reset and you can enter the password again.
Good luck with that.
Forgot password on cyclone voyager tablet
How to reset a Sumvision cyclone voyager 7'' - Tablets and e ...
forums.digitalspy.co.uk/showthread.php?t=1777470
Digital Spy
Dec 31, 2012 - 7 posts - ‎4 authors
Hi a friend of mine had a 7'' Sumvision Cyclone Voyager tablet for ... it round for me to look at last night, i tried to get the password reset but ...
Do you know how to reset a Sumvision Voyager Tablet, i ...
www.askmefast.com > ... > Screen
Cyclone voyager tablet how to reset stuk on android screen .... Sumvision cyclone voyager password reset · I forgot my .... Cyclone voyager 10 tablet factory reset.
Topic: Cyclone Voyager ' Tech It E@sy
I have forgotten my pattern lock on my tablet
Hi John, this is what I found for you>
To overcome this problem you must follow my steps;
  1. Keep Drawing the pattern number of times
  2. Then at one time it will recognize that you forgot your pattern
  3. Then it will ask for your E Mail ID and password
  4. Type them then you can log in
Also > Its really very bad when we forget our password....
So i am providing you few fixes to solve this....
Here is a simple fix first....
try pattern 5 times then it will show forget password...
then click on forget password and it will ask for your google account information fill the details
Once you filled the correct details it will ask to draw a new pattern....
If you do not have any details of google account then there are also some other ways to get this back .....
i am providing a link to you to get all the details about how to fix your problem.....
http://null-byte.wonderhowto.com/how...creen-0138807/
I turn my tab 795tpc iview wifi on but it turns off .. cant fuction the scan and network available.. what should i do.? Whats wrong w/my tab??
Try scanning for network but instead of logging in click arrow right and look for "forget network". this clears internal cache of any stored passwords that you may have recently changed.then scan again and it will ask for new password and this time remain logged in as you will have removed conflict.
1helpful
Network Connections
I'll give you a generalized answer because I am not familiar with the tablet you are using. The the principle is the same for all wireless devices. Go to their version of SETUP for wireless networks (for example, on the IPAD it looks like a gear symbol) and select the right network which will be chosen from a list they provide of nearby networks. You need to know the name of the network you're trying to get on. Don't try to type it. Select it from the list of available networks. When you do, it will most probably ask for the network password or key which you need. If you don't know it, then you need to find it. Sometimes it is on the base of the modem. Type it in carefully noting the caps and don't mix up zeroes and letter O, etc. It sounds like a password problem you are having so do this carefully. If it does not work, and If you use the network for your phone also, you can try logging the phone off the network and then logging back on with the password you think is right to confirm if it is a password problem but... if the password you are trying is wrong, you will now not be able to get your phone back on the network until you find the right password. Then you will also know how to fix the tablet log on as well. Hope that helps.
Put in wrong password for wifi and then accidentally hit forget and now it wont let me type in a password at all
You need to select the wi-fi website again, and enter the password again. It will then store the password.
If you forget the site, it forgets the password connection to the site and you have to start again.
2helpful
My irulu tablet is locked and even when I put in the log in and password it won't open just says too many pattern attempts how do I get in?
someone might be trying to open unlock it before you did and tried too many pattern combination. it mights just be banned for couple of hours/min but you can try again later. too many attempts of wrong pattern/password can be interpreted as freud.
1helpful
I have Fujitsu Stylistic Tablet and forgot my password. How do I get to start to enable me use the tablet?
Since the Password is missing, you will have to reinstall the Operating System only.
http://www.wikihow.com/Log-on-to-Windows-XP-if-You-Forget-Your-Password
Check the above link and you will find some steps to hack the Windows Password.
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
