I have a Samsung Waltz double door fridge, i had a noise from the fan for a few days and now the noise has gone so the fan has stopped and the fridge is not cooling as normal, freezer is working ok. This fan would switch off when the door was opened
Hi, It sounds to me like the evaporator fan motor is faulty. They will quit working after they make a noise like that, bearings and windings.You have a door switch that stops the fan when you open the door, that opens the contacts on the motor. It should have come back on when closing door. Now you say it has quit cooling,so if this motor has not come back on and is not running quietly, it will need to be removed and replaced.It may be difficult for you if you are going to do this yourself, but if your up to it, you can save yourself some $.You can buy a new one at an appliance parts house, or get all of the info from you're unit and go online to order one.They have universal motors to fit also.It would be a 120volt sealed motor with a plastic or aluminum blade.Try and remove it yourself if you are able, if not you will need to call out the tech which can get costly. Best of Luck to you and please keep me posted.Have a good night, Sincerely, Shastalaker7
If noise stops when you open the door, you may have a noisy fan (or could have ice build up, causing fan blade to hit ice and cause noise). I gather it is a frost-free model ie has a fan in the freezer compartment. If noise is caused by fan hitting ice build up, you may have a problem with the auto defrost system, as you should not get ice build up in a frost free.
Noise stops when you open door because fan turns off when door is opened.
my Matytag msd2456dew fridge fan is running, no ice bulid up on coils in freezer section, but no cold air to freeze anything in freezer section or cold air in fridge section. what can be the problem?
Sham
Most of f&p make this noise its most annoying,
but could also be ice buildup on the fan blades,
creaking and cracking is normal as the pipes expand and contract is these thin foamwall fridges, not nice fridges, insulation has been compromised to lower cost, they work twice as hard at keeping cool
